Is there a file size limit on attachments?
Try to enable ExtendBTFeatureFlags and then check. Make sure to reset NVRAM twice.
Also, ensure that your kexts and OpenCore are upto date.
Will do
ExtendBTFeatureFlags is turned on in OC, all kexts have been updated, and two NVRAM resets haven't solved the issue.
Clear the .plist files from Library/Preferences/SystemConfiguration and then check. It seems like the BT address could not be found.
Great. Will update the guide accordingly :)
Hi,
Thanks for all the explanations. However, I still have problems with Bluetooth on Monterey... Either the Bluetooth disconnects frequently, or the "bluetoothd" process starts running at full speed to use 400% of the processor and it crashes the Bluetooth.
My specs :
  • Motherboard : ASRock Z490 Phantom Gaming-ITX/TB3
  • CPU : Intel Core i9-10850K
  • GPU : AMD Radeon RX 6600
  • Network card : BCM94360NG
  • macOS version : 12.6 (21G115)
  • OpenCore version : 0.8.8
The network card (BCM94360NG) is in the M.2 key E port on the motherboard. WiFi works perfectly. Bluetooth is well mapped by USBMap.kext (HS14 = internal 255). I added -btlfxallowanyaddr flag on startup and the BlueToolFixup kext but my problems persist.
What is the problem? How to access the Bluetooth logs (and see what's wrong)? My EFI, IOreg folder and my PCIe Report are here: https://drive.google.com/file/d/1toCSCuw4Gs0972dt6EBHnb6eiFJCfhzL/view?usp=share_link
Thanks for your help
Write your reply...
moraWooChang
