Hello, my DW1820a worked fine on Big Sur, but not on Monterey 12.6.2. I've redone USB port mapping and used BlueToolFixup kexts to no avail. In System Preferences under Bluetooth it shows NULL Address, State is Off but the firmware is loaded. Please help Screen Shot 2023-01-19 at 00.37.32.png Screen Shot 2023-01-19 at 00.38.32.png
Hello, my DW1820a worked fine on Big Sur, but not on Monterey 12.6.2. I've redone USB port mapping and used BlueToolFixup kexts to no avail. In System Preferences under Bluetooth it shows NULL Address, State is Off but the firmware is loaded. Please helpView attachment 5501View attachment 5502
For this Card, you'll need to add additional kexts.
Refer to the guide linked below
I've put the kexts in OC/Kexts folder, BlueToolFixUp, BrcmFirmwareData, BrcmPatchRAM3. The result is as the screenshots provided. What am I missing?
No PR Files attached.
What should I attach that will provide adequate information?
Ok, I've attached PR Files.
Mhh, seems my zip attachments gets lost in the way after posting the reply
Please attach them again. Upload it first and then type your message.
rayd8
