How to Enable Intel HD Graphics (Haswell, Broadwell and Skylake) on macOS Ventura and Later
This guide covers fixing Intel Haswell, Broadwell and Skylake HD Graphics on Desktops and Laptops for macOS Ventura and Later. This guide supports both Clover and OpenCore Bootloader. By following this guide, you'll be able to achieve full QE/CI for your Haswell, Broadwell and Skylake systems.
macOS supports a wide range of Intel HD Graphics (also referred to as iGPU) but some of them might not work out of the box if you have not followed the Clover or OpenCore Installation Guide.
Before you start with this guide, please know something about the performance. Graphics enhance performance and helps to work smoothly. In macOS, full acceleration requires that both Quartz Extreme and Core Image (QE/CI) should work together.
Quartz Extreme and Core Image (QE/CI) should work together to enable full acceleration on macOS’s GUI. It utilizes the complete Graphics capabilities. In case you haven’t enabled QE/CI on your graphic card, you won’t be able to use your macOS smoothly and there would be lots of lags and artifacts, graphic-related issues, and poor refresh rate. Also, the dock would not be transparent. Therefore it is very important to ensure that your graphic is working with full QE/CI.
Unfortunately, with the announcement of macOS Ventura, Apple has officially dropped support up to Skylake, including IGPU support. If you check S/L/E, you'll notice that the support for IGPU is for KBL and later. This means Skylake CPUs will not have IGPU acceleration. However, there is still a workaround to get acceleration on macOS Ventura for Skylake users.
STEP 1: BIOS Setting
The BIOS settings have been provided in a separate thread. For more information on BIOS settings, refer to the thread linked below.
STEP 2: Set Framebuffer
macOS/OS X supports a range of Intel HD/UHD Graphics devices, however not all the variants present in Hackintosh devices are supported out of the box. This is because Apple uses only a few selected Intel CPUs for its Mac lineup and therefore the framebuffer and other required properties exist within macOS/OS X drivers. However, when it comes to Non-Apple computers, this is not the case and therefore you need to set framebuffer with a valid
The next step is to set the framebuffer depending on your CPU Code Name. To set the framebuffer, follow the steps below
1. Mount your ESP
2. Open your config.plist
3. Depending on your CPU model and the Graphics, select the framebuffer from the table below and depending on the bootloader you use, add the following properties to your config.plist under
4. Once you are done with adding the properties, save your config.plist
Haswell [Intel HD Graphics 4200, 4400, 4600, 5000, 5100, 5200]
Native Supported Device IDs:
Broadwell [Intel HD Graphics 5300, 5500, 5600, 6000, 6100, 6200, 6300]
Skylake [Intel HD Graphics 510, 515, 520, 530, 540, 550, 580]
STEP 3: Add Kext
The next step is to add a different version of WhateverGreen.kext which allows spoofing SKL as KBL. This will allow booting into macOS without any need for additional boot args and extra configuration. In addition, it will fix video playback issues and the Sleep/Wake function (for Laptops only). To add the kext, follow the steps below.
1. Visit WhateverGreen for spoofing SKL to KBL
2. Download Artifacts from the Artifacts section.
3. Extract and copy it to your EFI/OC/Kexts. You'll also need to add the kext entries in the Kernel section of your config.plist.
STEP 4: Disable Discrete Graphics (DGPU)
If you're using a Laptop and if it has dGPU, you'll likely need to disable it. To disable the dGPU, refer to the guide linked below.
elitemacx86.com
STEP 5: Configure SMBIOS
Depending on your Platform, you'll need to use a supported SMBIOS from the table below.
For more information on setting up SMBIOS, refer to the guide linked below.
elitemacx86.com
STEP 5: Restart your System
Now you should be able to get your Intel HD Graphics 5XX 1536 MB will full QE/CI. And your Dock would be also transparent.
Desktop
Laptop
Hackintool System Info
Problem Reporting
Details:
Credits :
PMHeart
dhinakg
| Graphics |
| Kexts | Original Graphics kexts in S/L/E |
| macOS Version | macOS Ventura and later |
| OpenCore Version | OC v0.8.2 and newer |
device-id (sometimes spoofed) and ig-platform-id for the graphics to work.The next step is to set the framebuffer depending on your CPU Code Name. To set the framebuffer, follow the steps below
1. Mount your ESP
Devices>Properties (for Clover) and DeviceProperties (for OpenCore)| Devices | Key | Value | Type | Notes |
| PciRoot(0x0)/Pci(0x2,0x0) | AAPL,ig-platform-id | Depends on your System | DATA |
| device-id | Depends on your System | DATA |
| enable-hdmi20 | 01000000 | DATA |
| framebuffer-fbmem | 00009000 | DATA |
| framebuffer-cursormem | 00009000 | DATA |
| framebuffer-patch-enable | 01000000 | DATA |
| framebuffer-stolenmem | 00003001 | DATA |
| hda-gfx | onboard-1 | STRING |
- 0x0d26
- 0x0a26
- 0x0a2e
- 0x0d22
- 0x0412
- AAPL,ig-platform-id:
- Desktop:
- 0300220D
- Laptop:
- 0000160A
- 0500260A
- 0600260A (Recommended)
- Headless/Empty Framebuffer:
- 04001204
- Desktop:
- device-id
- 12040000 (Required for HD4200/HD4400/HD4600)
- 0x0BD1
- 0x0BD2
- 0x0BD3
- 0x1606
- 0x160e
- 0x1616
- 0x161e
- 0x1626
- 0x1622
- 0x1612
- 0x162b
- Desktop:
- 07002216
- Laptop:
- 06002616
- Desktop:
- device-id
- 26160000 (Required for some HD5500/HD5600; enable as required)
- 0x1916
- 0x191E
- 0x1926
- 0x1927
- 0x1912
- 0x1932
- 0x1902
- 0x1917
- 0x193B
- 0x191B
- Desktop:
- 00001219
- Laptop:
- 00001B19 (Recommended)
- 00001619
- 00002619 (Required for HD550/P530)
- 01001219
- Desktop:
- device-id
- 02190000 (Required for HD510)
- 16190000 (Required for HD550/P530)
STEP 3: Add Kext
GUIDE - How to Disable Discrete Graphics in Dual GPU Laptops (NVIDIA/AMD) on macOS
How to Disable Discrete Graphics in Dual GPU Laptops (NVIDIA/AMD) on macOS An EliteMacx86 Exclusive Guide - This guide covers disabling Discrete Graphics in Dual GPU Laptops for NVIDIA and AMD on macOS. By following this guide, you'll be able to disable discrete graphics (NVIDIA/AMD) on your...
elitemacx86.com
| Platform | SMBIOS | Notes |
| Laptop | MacBookPro13,1 MacBookPro13,2 MacBookPro13,3 | -no_compat_check boot arg required. |
| Laptop | MacBookPro14,1 and Later | No need to use -no_compat_check boot arg. |
| Desktop | iMac17,1 | -no_compat_check boot arg required. |
| Desktop | iMac18,1 and Later Macmini8,1 and Later | No need to use -no_compat_check boot arg. |
GUIDE - How to Setup Correct SMBIOS [Clover/OpenCore]
How to Setup Correct SMBIOS [Clover/OpenCore] This guide covers setting up a Correct SMBIOS for Intel and AMD CPUs on macOS using Clover and OpenCore. By following this guide, you'll be able to set up the correct SMBIOS on your system using Clover or OpenCore Bootloader. I. What is SMBIOS...
elitemacx86.com
Desktop
Laptop
Problem Reporting
Details:
- macOS version
- Copy of IOReg
- Kextcache output
- DPCIManager/Status
- About This Mac
- System Information/Graphics/Displays
- For Clover, compress EFI/Clover, and exclude the themes folder.
- For OpenCore, compress EFI/OC.
- Do not include the complete EFI folder.
- Put all files in a folder with your name, compress files as Zip and attach files using site attachments only.
- Do not use any external links.
Credits :
PMHeart
dhinakg
