SOLVED Dell Inspiron 15R SE ( 7520) Monterey Post Installation
abdulahath
Dell Inspiron 15R SE 7520
Intel Core i5 3230M / Intel Ivy Bridge/HM77
Intel HD Graphics 4000 with AMD Radeon HD 7730M 1366x768
What kind of post-installation settings should i do to enable Battery , Audio, bluetooth?
Please advise .
Please advise .
For Battery Meter,
For Audio,
For Bluetooth,
For Battery Meter,
For Audio,
For Bluetooth,
1. After adding SMCBatteryManager.kext , ECEnabler.kext Battery percentage is now showing. It's done.
2. is there a Patcher / Tool like , OCLP for Audio ? patching with OCLP,"Post-intall volume patch" have been easier for me.
But the Audio guide is overwhelming and confusing.
3. is there a way to enable intel HD audio ( instead of my conexant CX20672-21Z ) easily with Opencore ACPI patch or Device properties add?
No, there is not. What is confusing? It's pretty easy. Add AppleALC.kext and Lilu is already present. Using alcid=xx, where xx represents the alcid, add it to your bootarg and it's done.
Do you mean HDMI Audio?
How can i find the alcid id for my hardware conexant CX20672-21Z ?
No, i just only need audio output from laptop speaker to be worked, quality is better or not, that is not a problem. If there is a easy way to get it done, please advise.
in your Audio guide, it's so many sub articles to refer and it's confusing for me.
Thanks
Yes, exactly.
i tried alcid=14, unfortunately it's not worked. I tried 3,12,13,14,28 nothing worked. in the list of AppleALC supported codecs github page, doesn't have my model "conexant CX20672-21Z". Can you help me please?
gopon_user
