Resolution is 1366 x 768
find attached Hackintool Pcle export
Now, you need to change the SIP to 030A0000 and patch the system volume with OCLP latest version.
I Finally acheived the graphic acceleration with your support. Thanks so much for your help.
Disabling the SIP with NVRAM-->csr-active-config doesn't work. I disabled the SIP through recovery mode -> terminal "csrutil disable". Then only i'm able to use the "Post-intall volume patch" . After the patching rebooted with the graphics acceleration.
Glad to hear that!
You're welcome!
Other parameters are required when disabling SIP for root patching.
Usually, not required but glad you were able to tackle it.
Closing this thread as the original issue is solved.
For the rest of the issues collectively,
ryusuke17
