Post Installation
Now, you're ready for Post Installation. As Post Installation involves several fixes including fine-tuning the installation. You can find a dedicated thread for post installation below. The following guide will serve both, Clover and OpenCore.
Troubleshooting
With certain systems, it might be possible that even when following the guide precisely, the system is unable to boot into the installer, or the installation not being completed. You can find a dedicated thread for troubleshooting below. The following guide will serve both, Clover and OpenCore.
I have done everything according to the guide but my system gets stuck in the boot logo.
No PR files attached.
It's been here like forever everytime i try boot it up it just gets stucked in here forever.
Can you help me by making efi folder for my system I'm sure that there might be something I'm missing in the efi folder that I created
No information without verbose. Enable verbose and attach the BIOS Settings and EFI you're using to boot.
I don’t think that there is any option for verbose in the dell bios. I’m using open core efi to boot. What to attach from the BIOS settings
Verbose can be enabled in your OpenCore config.plist in the Boot Arg section. Read here:
All the BIOS Settings. Take a picture of every setting and zip them to a folder and upload it here.
Can you like make a new efi folder for me from the oc_gen x or something cause I don’t have a Mac I made that efi file through my virtual Mac installed in my system.
It's your responsibility. If you don't have a Mac, the guide has instructions for Windows, Linux, and Mac.
chirag11122
