Broadcom DW1560 partially connects to the internet on macOS Ventura
novasimiti20
HP Pavilion 570
Intel Core i7-7400 (Kaby Lake)
Intel HD Graphics 630
So, recently, I installed macOS Ventura on my Lenovo ThinkPad T460 laptop.
Everything works fine, such as the spoofed Skylake Graphics, trackpoint buttons, everything. The only issue I have is the WiFi card - on Monterey to allow the WiFi to work of course I had to block the Brcm4360_Injector plugin from loading in OpenCore, therefore it would work. However, upon installing Ventura - the WiFi partially connects, which means I only have access to some websites (and they won't even load properly), plus Apple Services/Discord/other such apps not working. If I can have some help getting the WiFi to fully work again that would be beneficial.
You should delete the 4360 entry in the config.plist file and remove the driver loading arg as it is a preferred option.
This is more of a DNS issue. Make sure to use Google DNS, clear your browser's cache and cookies, and then check if you can access those. If it still does not work, try connecting to those sites using a VPN and then check.
I've resetted the DNS and it still didn't work, and neither using Google or OpenDNS solved any of these issues.
Sorry how can I make a PR report to show evidence?
No, PR files are Problem Reporting files, used for diagnostics.
Normally it includes EFI, IOReg, Hackintool PCIe export, System Report, Kextcache output.
Using OpenDNS and Google DNS didn't help.
This is my Hackintool PCI export: (I have to paste it here since due to the partial connection I cannot attach)
DEBUG VID DID SVID SDID ASPM Vendor Name Device Name Class Name SubClass Name IOReg Name IOReg IOName Device Path
00:00.0 8086 1904 17AA 5053 Disabl Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Bridge Host bridge /PCI0@0/MCHC@0 pci8086,1904 PciRoot(0x0)/Pci(0x0,0x0)
00:02.0 8086 5916 17AA 5053 Disabl Intel Corporation Intel HD Graphics 620 Display controller VGA compatible contr /PCI0@0/IGPU@2 display PciRoot(0x0)/Pci(0x2,0x0)
00:14.0 8086 9D2F 17AA 5053 Disabl Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller Serial bus controlle USB controller /PCI0@0/XHCI@14 pci8086,9d2f PciRoot(0x0)/Pci(0x14,0x0)
00:16.0 8086 9D3A 17AA 5053 Disabl Intel Corporation Sunrise Point-LP CSME HECI #1 Communication contro Communication contro /PCI0@0/IMEI@16 pci8086,9d3a PciRoot(0x0)/Pci(0x16,0x0)
00:14.2 8086 9D31 17AA 5053 Disabl Intel Corporation Sunrise Point-LP Thermal subsystem Signal processing co Signal processing co i8086,9d31@14,2 pci8086,9d31 PciRoot(0x0)/Pci(0x14,0x2)
00:17.0 8086 9D03 17AA 5053 Disabl Intel Corporation Sunrise Point-LP SATA Controller [AHCI mode] Mass storage control SATA controller /PCI0@0/SAT1@17 pci8086,9d03 PciRoot(0x0)/Pci(0x17,0x0)
00:1C.0 8086 9D10 0000 0000 L1 Intel Corporation Sunrise Point-LP PCI Express Root Port #1 Bridge PCI bridge /PCI0@0/EXP1@1C pci-bridge PciRoot(0x0)/Pci(0x1C,0x0)
00:1C.2 8086 9D12 0000 0000 L0s+L1 Intel Corporation Sunrise Point-LP PCI Express Root Port #3 Bridge PCI bridge CI0@0/EXP3@1C,2 pci-bridge PciRoot(0x0)/Pci(0x1C,0x2)
00:1F.0 8086 9D48 17AA 5053 Disabl Intel Corporation Sunrise Point-LP LPC Controller Bridge ISA bridge /PCI0@0/LPC@1F pci8086,9d48 PciRoot(0x0)/Pci(0x1F,0x0)
00:1F.2 8086 9D21 17AA 5053 Disabl Intel Corporation Sunrise Point-LP PMC Memory controller Memory controller i8086,9d21@1F,2 pci8086,9d21 PciRoot(0x0)/Pci(0x1F,0x2)
00:1F.3 8086 9D70 17AA 5053 Disabl Intel Corporation Sunrise Point-LP HD Audio Multimedia controlle Audio device CI0@0/HDEF@1F,3 pci8086,9d70 PciRoot(0x0)/Pci(0x1F,0x3)
00:1F.4 8086 9D23 17AA 5053 Disabl Intel Corporation Sunrise Point-LP SMBus Serial bus controlle SMBus CI0@0/SMBU@1F,4 pci8086,9d23 PciRoot(0x0)/Pci(0x1F,0x4)
00:1F.6 8086 156F 17AA 2233 Disabl Intel Corporation Ethernet Connection I219-LM Network controller Ethernet controller CI0@0/IGBE@1F,6 ethernet PciRoot(0x0)/Pci(0x1F,0x6)
02:00.0 10EC 522A 17AA 5053 L1 Realtek Semiconductor Co., Ltd RTS522A PCI Express Card Reader Unassigned class ??? /EXP1@1C/PXSX@0 pci10ec,522a PciRoot(0x0)/Pci(0x1C,0x0)/Pci(0x0,0x0)
04:00.0 14E4 43B1 106B 0019 Disabl Broadcom Inc. and subsidiaries BCM4352 802.11ac Wireless Network Adapter Network controller Network controller XP3@1C,2/ARPT@0 pci14e4,43b1 PciRoot(0x0)/Pci(0x1C,0x2)/Pci(0x0,0x0)
  • pcidevices.txt
    pcidevices.txt
Everything must be in a single .zip file. Note that IOReg and EFI requires a complete file, not a screenshot. Upload it on the forum or the Google Drive/WeTransfer and share the link.
lovos33
