A lot of app doesn't work
Z2VvZ2Vv
Acer Veriton X2631G i5 4460
i5 4460
GT 1030
I recently installed my hackintosh and all works fine except button "ok" in Plans, Chrome (not start just a white page) and Firefox (launch but freeze). Have you any ideas of the problem ? Also when I record my screen with "screenshot" the result is just a blue background and the cursor. It's related to that ? NB : Safari works fine.
Thanks.
Thanks.
This could be a result of GT 1030 being used in Monterey. Note that only High Sierra supports Pascal GPUs. Since Mojave, there are no WebDrivers. As you have an IGPU compatible CPU, the solution is to use IGPU or upgrade to a different GPU that is supported on Monterey or you can also install High Sierra. Choose one according to your preference.
To confirm the issue, disable NVIDIA Drivers using nv_disable=1 in your boot args and then check if you can open Chrome and Firefox. If yes, you know the reason now.
I've tried the boot args and it's do nothing. I searched and i found the problem, it's the SIP (when it's disabled almost all application download on the web don't work, i don't know the reason but that's it). After knowing the problem i tried to disable the sip with kext of GT1030 and the boot args but macOS don't boot up. I think i will be finally use my Macbook because the app that i would have on macOS on desktop don't works.
With the NVIDIA disabled, do you still have acceleration? Do Apps work?
SIP can be either enabled or disabled. What's your SIP status? White screen with SIP enabled or disabled cannot be an issue for sure as i have tested both of them at my end.
Disabling SIP doesn't require any Kext involvement. With OpenCore, the SIP can be disabled in NVRAM>csr-active-config with a value of 67000000. Nothing more is required.
Well, it is up to you.
jonsv2
