MONTEREY INSTALLation help
zazzydou
@zazzydou@B
Ryzen 9 3900x
Msi Rx 6600
  1. iMac Pro
CPU :Amd ryzen 9 3900x
GPU:RX 6600 8GB
MOBO:B550M DS3H AC
SSD:HP SSD EX900 250GB NVME
i trt installing MOnterey on this build but nothing do
GPU:RX 6600 8GB
MOBO:B550M DS3H AC
Your system is compatible. You should be able to install it.
i created an efi folder as per the site guidance but im getting issue?
It actually depends. If there's anything missing in the configuration, you'll have the issue. If not, you should be able to boot the installer.
can someone help me or create an EFI folder as per my set up in the attachment plz
fdraili
