How to Enable Intel Skylake Graphics (Intel HD Graphics 515, 520, 530, 540, 550 and 580) on macOS Ventura and Later
An EliteMacx86 Exclusive Guide - This guide covers fixing Intel Skylake Graphics on Desktops and Laptops for macOS Ventura and Later. By following this guide, you'll be able to achieve full QE/CI on your system.
macOS supports a wide range of Intel HD Graphics (also referred to as iGPU) but some of them might not work out of the box if you have not followed the Clover or OpenCore Installation Guide.
Before you start with this guide, please know something about the performance. Graphics enhance the performance and helps to work smoothly. In macOS, full acceleration requires that both Quartz Extreme and Core Image (QE/CI) should work together.
Quartz Extreme and Core Image (QE/CI) should work together to enable full acceleration on macOS’s GUI. It utilizes the complete Graphics capabilities. In case you haven’t enabled QE/CI on your graphic card, you won’t be able to use your macOS smoothly and there would be lots of lags and artifacts, graphic-related issues, and poor refresh rate. Also, the dock would not be transparent. Therefore it is very important to ensure that your graphic is working with full QE/CI.
Unfortunately, with the announcement of macOS Ventura, Apple has officially dropped support up to Skylake, including IGPU support. If you check S/L/E, you'll notice that the support for IGPU is for KBL and later. This means Skylake CPUs will not have IGPU acceleration. However, there is still a workaround to get acceleration on macOS Ventura for Skylake users.
STEP 1: BIOS Setting
The BIOS settings have been provided in a separate thread. For more information on BIOS settings, refer to the thread linked below.
STEP 2: Add Required Kexts
The next step is to add the required kexts to enable Graphics and to use the WhateverGreen properties. WhateverGreen doesn't work standalone. Lilu and WhateverGreen are needed together to work in conjunction.
1. Download Lilu and WhateverGreen from the downloads section of this forum.
For Clover:
If you're using Clover, copy both the kexts to EFI/Clover/Kext/Others
For OpenCore:
If you're using OpenCore, copy both the kexts to EFI/OC/Kexts. You'll also need to add the kext entries in the Kernel section of your config.plist.
STEP 3: Soof GPU Properties
The next step is to modify the config.plist and spoof the GPU properties SKL as KBL.
1. Mount your ESP.
2. Open your config.plist.
3. Depending on the bootloader you use, add the following properties to your config.plist under
4. Once you are done with adding the properties, save your config.plist
STEP 4: Disable DGPU
If you're using a Laptop and it has dGPU, you'll likely need to disable it. To disable the dGPU, refer to the guide linked below.
STEP 5: Setup SMBIOS
Depending on your Platform, you'll need to use a supported SMBIOS from the table below.
For more information on setting up SMBIOS, refer to the guide linked below.
STEP 5: Restart your System
Now you should be able to get your Intel HD Graphics 5XX 1536 MB will full QE/CI. And your Dock would be also transparent.
Verifying Graphics Acceleration
Desktop
Laptop
Hackintool System Info
Problem Reporting
Details:
Credits :
PMHeart
dhinakg
Graphics | Intel Skylake Graphics (HD 515, 520, 530 and 540) Desktop or Mobile |
Kexts | Original Graphics kexts in S/L/E Lilu and WhateverGreen |
macOS Version | macOS Ventura and later |
For Clover:
For OpenCore:
1. Mount your ESP.
Devices>Properties
(for Clover) and DeviceProperties
(for OpenCore)Devices | Key | Value | Type | Notes |
PciRoot(0x0)/Pci(0x2,0x0) | AAPL,ig-platform-id | Depends on your System | DATA |
device-id | 16590000 | DATA |
enable-hdmi20 | 01000000 | DATA |
framebuffer-fbmem | 00009000 | DATA |
framebuffer-patch-enable | 01000000 | DATA |
framebuffer-stolenmem | 00003001 | DATA |
hda-gfx | onboard-1 | STRING |
GUIDE - How to Disable Discrete Graphics in Dual GPU Laptops (NVIDIA/AMD) on macOS
How to Disable Discrete Graphics in Dual GPU Laptops (NVIDIA/AMD) on macOS An EliteMacx86 Exclusive Guide - This guide covers disabling Discrete Graphics in Dual GPU Laptops for NVIDIA and AMD on macOS. By following this guide, you'll be able to disable discrete graphics (NVIDIA/AMD) on your...
elitemacx86.com
Platform | SMBIOS | Notes |
Laptop | MacBookPro13,1, MacBookPro13,2, MacBookPro13,3 | -no_compat_check boot arg required. |
Laptop | MacBookPro14,1 and Later | No need to use -no_compat_check boot arg. |
Desktop | iMac17,1 | -no_compat_check boot arg required. |
Desktop | iMac18,1 and Later Macmini8,1 and Later | No need to use -no_compat_check boot arg. |
GUIDE - How to Setup Correct SMBIOS [Clover/OpenCore]
How to Setup Correct SMBIOS [Clover/OpenCore] This guide covers setting up a Correct SMBIOS for Intel and AMD CPUs on macOS using Clover and OpenCore. By following this guide, you'll be able to set up the correct SMBIOS on your system using Clover or OpenCore Bootloader. I. What is SMBIOS...
elitemacx86.com
Desktop
Laptop
Problem Reporting
Details:
- macOS version
- Copy of IOReg
- Kextcache output
- DPCIManager/Status
- About This Mac
- System Information/Graphics/Displays
- For Clover, compress EFI/Clover, and exclude the themes folder.
- For OpenCore, compress EFI/OC.
- Do not include the complete EFI folder.
- Put all files in a folder with your name, compress files as Zip and attach files using site attachments only.
- Do not use any external links.
Credits :
PMHeart
dhinakg
