AppleALC Earphone mic not working
Pranay
Hp Elitebook 840 G3 motherboard
Intel(R) Core(TM) i5-6300U CPU @ 2.40GHz 2.50 GHz
Intel HD Graphics 520
  2. Clover (Legacy)
  3. OpenCore (UEFI)
  4. OpenCore (Legacy)
  2. iMac Pro
  3. Mac Pro
  4. Mac mini
  5. MacBook
  6. MacBook Air
  7. MacBook Pro
  3. Windows Phone
  4. Other
Hey Team EliteMacX86 I wanted to use my Earphone microphone as my manditory as my inbuilt microphone is not so good quality but the problem is I use Lates AppleALC kext and it is not showing me my extrernal microphone only internal is been shown is there any fix?
What's your Codec?
Layout ID seems to be correct. Maybe you can try with another Headphone?
It seems to be a problem with My AppleALC I am not sure cause before I was using a brebuilt EFI for my laptop which's AppleALC's external micrphone was working but the mic would stop to work after about 30 sec so I created a Freshly new EFI and took the latest AppleALC and then the external micrphone is not showing up in SystemPreferences .I tried my sony headphones and it didn't work.
No PR files attached.
What else do u need ?
- IOReg
- Kextcache output
- Hackintool PCIe Report
- System Report
- System Preferences>Sound>Input and Output screenshots
- Old EFI where you had the Headphones working
- Original ACPI files
dannyrodri22
