AppleALC Earphone mic not working
Ok i tried that but now the Brightness,battery indicator and external microphone is not working :(.
EFI
Please review the above FILES
EFI
Please review
As per your previous configuration, there was no sign of External Headphones working and such things are complex on macOS as most of the time, it requires a custom XML patching.
For the current EFI, here are the issues
- Change GFX0 to IGPU in SSDT-PNLF
- Add Battery patch in DSDT
How do i change SSDT-PNLF.aml to dsl to apply patch?
and also i can't find battery patch in dsdt
You don't need to change it to DSL. Just use Find and Replace option.
For Battery Meter
For Battery Meter
My laptop Which is a HP elitebook 840 g1 patch is not available in RehubMan patch so how do i patch?
Use Elite X2 to check. If that fails, you can use the patches from the following repo
Hey Elite X2 did not work but when i user that repo it did not show in my patch . :(
Can u please attach the AppleALC which u are using so that i can see if the problem with AppleALC or patch.
ThankYou.
scoobypetey
