Installing Big Sur on Dell G3 15 Gaming (3500) Black (i5)
The notebook has the following:
Network Adapter Realtek PCIe GbE Family Controller
Network Adapter Intel (R) Wireless-AC 9462
By the question, do you think I have Realtek set up in config.plist?
I'll make adjustments tomorrow, try the installation and give info
Surely!
I made the adjustments as instructed by the example screen, including trying to load the installer. What should I do for a successful implementation?
The issue is Root Device Not found, which is usually a SATA/USB issue.
In BIOS, make sure you have set SATA Mode to AHCI. I already provided you with the BIOS settings link.
Sure, I've already set everything up according to your instructions, and that was the result :(
Is your USB 2.0 or 3.0, the flash Drive? Also, in Windows, find the SATA Controller information. Provide Device ID and Vendor ID to check further.
For more information about NTB by sending a report:
here
all
g.gott81
