iMac A1312 - Upgrade to Big Sur
leandro077
A1312 / 820-2901
I5-760
HD5750
11.0.x
Hello,
I have got multiple issues here.
I recently bought a iMac 27" from Mid 2010. The person I bought it from told me that the logicboard was broken, but showed me the GPU that was taken out by an "expert".
My first question is how can I find out if it's just the GPU or the whole logicboard that's broken?
Next question:
I wanted to upgrade the iMac to Big Sur. I realize that I need a metal GPU. I had the HD 8970m in mind as it is an MXM size and the most recent I can get.
As far as I understood this from the guides it will be compatible, but I won't have a bootscreen etc as it is not an Applecard. So I need to flash it right? Is there a flash available for this card? Or are there better options?
Thanks in advance ✌🏻
(And if the thread is in the wrong space, please move it or tell me to do so, I am always a bit confused in forums 😅)
You can do a physical inspection of the logic board.
Yes, that's correct. The card needs to be flashed. A guide will be published very soon. Also, this will not boot Big Sur natively, you'll need to use OpenCore for that.
XChikuX
