Actually, here is the fix. This works on most of the new HP Laptops and Mini PC.
Use the following patches.
TableSignature*: DSDT
Find: 47017000 70000108
Replace: 47017000 70000102
Comment: RTC Fix
Identifier*: com.apple.driver.AppleRTC
Base: __ZN8AppleRTC18setupDateTimeAlarmEPK11RTCDateTime
Comment: Disable RTC wake scheduling
Replace: C3
MinKernel: 19.0.0
Enabled: YES
Enable DisableRtcChecksum under Kernel section.
Can you please tell me how to add them in the config.plist, i never did plist renames.
Cause never needed.
Or can you just give me the XML format.
And also under which section to add these patches.
Or can you just help me adding those in my plist , will be very helpful and also i will get to know how to use these kind of patches.
Sorry for asking you to do everything.
Oh, damn. First will go into ACPI>Patch section
Second patch will go into Kernel>Patch section
Ok I tried to do what i can please have a look at my config.plist and let me know if i am missing something.
Also do i have to patch the Rehabman's RTC fix for this to work or there is no need of any other patch , just the renames will do the work?
I already mentioned that when using Hotpatch, DSDT is not required at all.
No i am not using hotpatch.
I kepth the static patched dsdt.aml only.
Even then, the above patch is necessary for the RTC issue on HP hardware.
dmitriy103
