Rahul12q
HP Pavilion 15-bc008tx
Intel Core i7 6700 HQ (Skylake)
1) Intel(R) HD Graphics 530(BIOS Device Name = \_SB.PCI0.GFX0) 2) Nvidia GTX 960m
11.0.x
  1. OpenCore
I installed MacOS Catalina a few days ago. The only thing that does not work properly is the battery indicator.
I created a patch using rehabman's guide on how to patch battery dsdt, using the patch i got the battery indicator to show but the battery meter does not update while plugged or unplugged.
The battery percentage only updates after a reboot , and also the percentage is accurate as i compared it with my windows 10 battery percentage.
I am attaching my original DSDT, patched DSDT and EFI folder please have a look and let me know what can I do to get this solved.
  • EFI.zip
  • DSDT_Original.dsl.zip
  • DSDT_Fixed_Bat.dsl.zip
11.0.x
  1. OpenCore
Fix your profile. In Motherboard, you should mention your Laptop model no.
Rahul12q
11.0.x
  1. OpenCore
11.0.x
  1. OpenCore
Updated the profile
Incomplete PR files attached.
- Kextcache output is missing.
- IOReg is missing.
- Original ACPI files are missing.
Rahul12q
11.0.x
  1. OpenCore
- IOReg is missing.
I have no idea how to get IOReg and Kextcache output.
Also which original ACPI files are missing.
I am sorry but am new in Hackintoshing so not much familiar with these things.
Rahul12q
11.0.x
  1. OpenCore
I found the way to post PR files from tonymacx86 site
Here are my PR files.
Also one more thing right now I am booted to the MacOS BigSur.
On Catalina the battery started to work perfectly now.
But on BigSur again I am facing the same issue.
Battery indicator does not update.
  • debug_11029.zip
11.0.x
  1. OpenCore
Remove abm_firstpolldelay=64000 from your boot args and then reset and check.
Rahul12q
11.0.x
  1. OpenCore
Removed the boot flag but still getting the same behavior for the battery.
I don't understand why on Catalina Everything works perfectly but on BigSur this battery meter does not update.
11.0.x
  1. OpenCore
ACPI is not patched.
Rahul12q
11.0.x
  1. OpenCore
Followed the guide and created full DSDT+SSDT patch , I patched all the common patches recommended for DSDT and SSDT .
But now I lost my brightness and the battery indicator is stuck at 100% forever.
Please help
Attaching PR and EFI
  • debug_32774.zip
  • EFI.zip
arxbox
