Rahul12q
HP Pavilion 15-bc008tx
Intel Core i7 6700 HQ (Skylake)
1) Intel(R) HD Graphics 530(BIOS Device Name = \_SB.PCI0.GFX0) 2) Nvidia GTX 960m
10.13.x
I installed MacOS Catalina a few days ago. The only thing that does not work properly is the battery indicator.
I created a patch using rehabman's guide on how to patch battery dsdt, using the patch i got the battery indicator to show but the battery meter does not update while plugged or unplugged.
The battery percentage only updates after a reboot , and also the percentage is accurate as i compared it with my windows 10 battery percentage.
I am attaching my original DSDT, patched DSDT and EFI folder please have a look and let me know what can I do to get this solved.
Fix your profile. In Motherboard, you should mention your Laptop model no.
Updated the profile
Incomplete PR files attached.
- Kextcache output is missing.
- IOReg is missing.
- Original ACPI files are missing.
- IOReg is missing.
I have no idea how to get IOReg and Kextcache output.
Also which original ACPI files are missing.
I am sorry but am new in Hackintoshing so not much familiar with these things.
I found the way to post PR files from tonymacx86 site
Here are my PR files.
Also one more thing right now I am booted to the MacOS BigSur.
On Catalina the battery started to work perfectly now.
But on BigSur again I am facing the same issue.
Battery indicator does not update.
Remove abm_firstpolldelay=64000 from your boot args and then reset and check.
Removed the boot flag but still getting the same behavior for the battery.
I don't understand why on Catalina Everything works perfectly but on BigSur this battery meter does not update.
ACPI is not patched.
Followed the guide and created full DSDT+SSDT patch , I patched all the common patches recommended for DSDT and SSDT .
But now I lost my brightness and the battery indicator is stuck at 100% forever.
Please help
Attaching PR and EFI
alvarg82
