 - Jun 10, 2021
 - HP Pavilion 15-bc008tx
 - Intel Core i7 6700 HQ (Skylake)
 - 1) Intel(R) HD Graphics 530(BIOS Device Name = \_SB.PCI0.GFX0) 2) Nvidia GTX 960m
 - 10.13.x
I installed MacOS Catalina a few days ago. The only thing that does not work properly is the battery indicator.
I created a patch using rehabman's guide on how to patch battery dsdt, using the patch i got the battery indicator to show but the battery meter does not update while plugged or unplugged.
The battery percentage only updates after a reboot , and also the percentage is accurate as i compared it with my windows 10 battery percentage.
I am attaching my original DSDT, patched DSDT and EFI folder please have a look and let me know what can I do to get this solved.
