- May 20, 2021
- MSI MEG Z590 ACE Gold Edition
- Intel i9 11900K
- ASRock Radeon RX 6700XT Challenger Pro 12GB OC
- 10.13.x
- iMac Pro
Hello, i am planning building a new and hopefully my last build on BigSur.
My interesst is very much in Thunderbolt 4 and the experiment getting macOS running on a 590 Chipset.
After couple of days making research i´ve found couple of mainboards i am interessted and i was shrink the number to only 2-3 mainboards.
Now I wonne ask you if you can advise me at the chloice and help me finding out if the board (setup) will be compability to macOS BigSur amd OC.
Here the boards:
Can you maybe give me a short advise about the pro/contras of each board?
I also have to say that i like to use a i9 11900K with the setup and 16-32 GB DDR4 RAM
Graphics Card is not sure when i am able to buy a used card of AMD 6800 or 6900 product line.
Edit:
One question I also have: Does macOS support 11th generation Intel procesasors, lets say i9 11900K?
Thank you very much,
greetz,
utilman
Here the boards:
Edit:
greetz,
utilman
