HP Pavilion G6 1250ej
Well, I decided to give up on this laptop as a Hackintosh.
The main reason is that High Sierra isn't supported anymore by Apple.
If I will manage to fix the BIOS on this laptop one day, I'll probably either install Windows or Linux on it, or just sell it and get an M1 Mac instead.
In other notes:
I am using the BCM94352HMB card (you recommended me to buy) on my Desktop Hackintosh now, which is running Big Sur with OpenCore.
I got WiFi to work, but still struggling to get Bluetooth up and running.
In other notes:
Bluetooth is connected via USB Bus. Make sure USB ports are mapped. For more information, read here:
All my USB ports are functional already thanks to USBInjectAll.
Is it necessary to map them for Bluetooth even if I have USBInjectAll already?
Yes, mapping is necessary. Provide PR files to check for the issue you have.
I’ll probably make a new post
Because it’s not related to this one
But going to try to map it myself first
Alright, I mapped my USB ports, Bluetooth still doesn't work and my USB 3.0 ports stopped working with USB 2.0 devices.
I'll create a new thread here with my PR files and specs.
Quick update
I think
That I found it
qhdcjm
