ASMedia USB 3.0 Ports not working on macOS Big Sur
ASMedia controller is enabled in the BIOS.
PR:
PR:
The kext is attached to the Controller.
- Enable EUSB to EH01 and USBE to EH02 renames in your config.plist.
- Remove SSDT-USB-Reset
Actually, with this modifications the front USB2 stop working.
Disable patch and enable Release UsbOwnership
Ok...then it doesn't work either...no USB2 or 3..with these changes.
Add Rename EHC1 to EH01and EHC2 to EH02 to your config.plist
alvarg82
