ASMedia USB 3.0 Ports not working on macOS Big Sur
jr3k
Asus P9X79 Pro
Intel Core i7-3930K
NVIDIA GeForce GTX 680
10.14.x
Hi
I have managed to upgrade my system to Big Sur on a X79 system, but the only thing left to have everything working is making the front USB ports (2 USB2 and 2 USB3) work. So far I have been struggling with it.
Any help or suggestions are appreciated ...
Thanks
Hi
Thanks
No PR files attached. Provide IOReg and a screenshot of DPCI Manager with the PCI List. You can use Hackintool and export the PCI List.
The configuration is not upto the mark. You're using kexts and configuration which doesn't applies to your system.
See if my PR is ok or missing something. Thanks
Here it is the Hacktool list I had forgotten.
Also, I have managed to get the front USB2.0 working, but not the 3.0.
Incomplete PR files attached. No Kextcache output attached.
Add mXHCD.kext and you should be good to go.
Never heard of that one....Is the one installed by USB.3.0.NEC package installer?
ASMedia and NEC (Renesas) are two different Controllers and manufacturer.
Mang0112
