SOLVED How to Fix WiFi detected but not working on macOS
The latest itlwm kext is v2.3.0. Try to update the kext and then check
Yes sure, Bro
I also tested different Airportitlwm.kext and itlwm.kext
Take a look at the block IOPowerManagement
[releases] OpenIntelWireless/itlwm
This kext is download to be from the repository itlwm_v2.3.0_stable.kext.zip
Yes sure, Bro
Don't inject both. Run Heliport and provide a video. However, it seems like the kext isn't attaching.
jonnyrec
