Two-step Verification and forum Navigation Issues
arsradu
Super Moderator
MSi Z97S SLI Krait Edition
Intel Core i5-4750
MSI Nvidia GTX 650 OC 2GB DDR5
10.13.x
Hi guys,
Well, maybe it would be better to have a separate section for Site Issues...just like we have for Suggestions? Just so that people can easily find that? It's not really intuitive to look for Site Issues into the Suggestions section. Just my opinion. I guess that would be my suggestion. LOL
Also, nobody likes issues, but...well, sometimes they do occur. :) And it would be nice to have them all in one place for fixing.
So I'd like to open this thread for the few site issues I've found so far (will update this thread as soon as I have more info, either from my experience, or from other members).
Not sure if all the users are now required to use two-factor authentication for login. I don't remember having to activate that, as a regular user. But...anyway. It's an issue. :)
The code generated for two-factor authentication doesn't seem to work.... Just in case it make any difference, I copy-pasted it. Also, it looks like it doesn't support codes that long....? Looks like the code is cut off at the end. Or maybe I did something wrong. Would like a confirmation on that, if possible.
Also, I guess this is not the way to "enter the secret" into the app directly... :)) One word missing there: code.
Also, small issue with the word spacing there.
Well, i think it would be good if we separate both. "Site Suggestions" and "Site Issues" or the errors.
It's an optional feature for the two-factor authentication or the two- step verification. For all the Account security, we recommend to use this authentication feature. Once enabled, you'll need to enter the code sent to your mail or the phone and then you can login into your Account on this forum.
To activate this feature, login into your Account, go to Account Settings and select Password and Security and you can enable two-step verification by selecting one of the option available.
The Code generated for two-factor authentication does work. I used a test account before reporting it to the Site Administrator. The issue is definitely from your end. I used iPhone and Google Authenticator, time based and once the time is lapsed, you'll need to enter the different Code. The scan code appears to be correct and the code received, is also correct. When filled, the feature is enabled. I also tested it with Android running Oreo 8.0. As expected, the feature works via scan code and manually entry of Code.
So i suggest you to check it again and then report back to us.
img_0553-png.590
Yes, i wonder how it got missed. This is actually missing. We'll try to fix it as soon as possible.
img_0555-png.591
It's not a spacing issue but wrong implementation of the replies in Mobile style. This is issue and we're working on it. We'll update once it's fixed.
Thanks
The "Code" issue has been fixed. You can find the new change in the screenshot attached below.
The two-factor authentication issue was definitely my bad. Sorry about that. :D The codes generated with Google Athenticator work properly indeed. However, the two-step authentication process itself doesn't seem to be optional. Yesterday, I couldn't do anything until I switched that on. :)) I mean, I don't mind. But if it's supposed to be optional (though recommended), right now, it doesn't look like it is. Or at least not for me. Maybe it is optional for regular users. Because, as a regular user, I wasn't required to switch to that immediately. But as a mod, I couldn't do anything or see anything until I switched that on. :)
No worries
The codes generated with Google Athenticator work properly indeed. However, the two-step authentication process itself doesn't seem to be optional. Yesterday, I couldn't do anything until I switched that on. :)) I mean, I don't mind. But if it's supposed to be optional, right now, it doesn't look like it is. Or at least not for me. Maybe it is optional for regular users. Because, as a regular user, I wasn't required to switch to that immediately. But as a mod, I couldn't do anything or see anything until I switched that on. :)
Well, As a Administrator, i checked this thing. And also setup a test account, and it works like a charm.
By default, the two-step verification isn't enabled for any accounts. But once you enable it, you'll need to set it up. You can disable and enable it anytime.
fly.gao
