Ok i have created the thread... What do i post 🤔
Ok i will... But what do i call the thread and how fo i name the request
You can use a thread title like "Unable to disable NVIDIA Graphics on whatever your Laptop model is"
I also see that your profile is not fixed. Please fix your profile. In the Motherboard, fill out the laptop model no. In the CPU, use the CPU model no.
I've created the thread, adjusted my profile... (mac os 10.15 beta to mac os 10.15.) I specified my Cpu... Which is Intel® Core™ i7-8550U Processor (Kabylake Refresh)
In the Motherboard, you must use the Laptop model no.
I cannot find the thread you created. To create a thread, go to the forums, click on Post thread, select your category and create.
Hey, how do you set the keys to adjust the screen brightness on a laptop keyboard ?? Right now it's fn + f12 and fn + key pause. My bootloader is opencore. In my laptop acer v3-371, the shortcut from adjusting the screen brightness on the keyboard is the shortcut fn + left arrow key and fn + arrow right key.
Hi, I disassembled DSDT and SSDT successfully.
opened DSDT file with MaciASL and complied with no error.
The main question is that you named some common patches in the guide, how can I understand which one I need ? and what other patches I need for my system ?
here is my known problems :
1. No Audio : Audio Device Realtek ALC255
2. touchPad won't work : ASUS Precision Touchpad
3. no wifi : wifi 5 802.11ac
4. no battery state
5. keyboard backlight is always on
6. Fingerprint reader not work
7. HDMI not work
8. when system go to sleep never wake up!
DPCIManager state attached.
EFI Folder (themes deleted) : elitemacx86.com EFI ASUS K571GT laptop
system spec details :
CPU i7-9750H Coffee Lake
graphic NVIDIA GeForce GTX 1650 - Intel® UHD Graphics 630
battery Lithium Polymer (LiPo)
RAM. DDR4 16 gig 2666MHz
Well, that's already explained in the guide.
DSDT is not patched. No HDAS to HDEF rename added. No Layout ID injected.
Probably, I2C Trackpad. Check Alexandred's VoodooI2C work.
Probably Atheros Killer or Intel which is unsupported and must be replaced with a compatible card.
no battery state
DSDT must be patched.
Finger print is unsupported and will NOT work.
HDMI not work
Framebuffer patching is required.
NVRAM issue.
The configuration is not as per the guide. Start here:
rayd8
