[SOLVED] Lenovo Z500 audio issue
You must be missing something then. Check for updates on the forum. Will check and provide you a solution.
no, I followed the guide step by step and tried all listed layout IDs for this codec but result was nothing
I'll check it.
thank you so much
it fixed using AppleALC and layout ID = 29 in 3 places ( clover config.plist > devices > audio > inject , clover config.plist > devices > properties > layout-id , DSDT)
thank you so much
Mark SOLVED.
chun1980
