After applying Intel HD Graphics 630 fix Catalina boots in blank screen
stp
Asus H110m-CS
Intel Core I3 7100
10.13.x
  1. MacBook Air
Hello! I have recently installed Hackintosh Catalina 10.15.3 on my PC . and after fixing HD Graphics MacOS boots in blank screen. But Everything else is working , CPU fan is on ,lights , mouse light, keyboard caps lock key light is working, i can hear error sound while smashing random keys on keyboard. i tried to disable AGDP but no luck.
HERE is my system config.
Intel Core I3 7100
Intel HD Gfx 630
Asus H110m-CS
i have attached my config.
Intel Core I3 7100
Intel HD Gfx 630
Asus H110m-CS
Incomplete PR files attached.
dear how am I supposed to get .ioreg file if my screen is blank.
Boot using invalid ig-platform-id and provide your PR files.
this .ioreg file was created after booting with other config.plist file . Throough this file it boots properly with no gfx acceleration. That config with blank screen had gIOScreenLockState KP. thank you for your time.
Attach kextcache output.
sudo kextcache -i/
config2.plist file boots with no gfx acc. with display output.
configworks.plist boots with gfx but no display output.
J.An
