Check the following guide for a better understanding.
thanks
I'm doing patch from beginning
should I do all patches that you did on that tutorial? for example these two patches are not in general patching guide :
  • Rename _DSM to _XDSM
  • Dell Inspiron 15-7xxx
also I didn't understand this :
For activating keyboard Brightness/Backlight Hot keys
  • UP = _Q1C
  • Down = _Q1D
and how do I find what USB _PRW patch should I use?
what version of OS Check Fix should I use?
thanks
It's already mentioned in the guide. Check for Windows 10. If it doesn't works, use Windows 8.
  • UP = _Q1C
  • Down = _Q1D
I read the guide but didn't get how to find what USB _PRW patch should I use?
should I just search for _PRW and see there is 0x6D or 0x0D ?
And why you want to do that?. I just mentioned it for example.
These two patches are specific to that laptop only.
Probably, you did NOT read the guide. I've already mentioned in the notes.
Search in your DSDT to find what method is used.
ok thanks so much
I must check all 41 layout IDs in the last I'll tell you the result
ryusuke17
