Hi, I wasn't sure whether I should keep the SSDT-PNLF as well as SSDT-PNLFCFL?
Just add the following.
Comment: Fix 300-series RTC Bug
Find* [HEX]: A00A9353 54415301
Replace*[HEX]: A00A910A FF0BFFFF
Hello,
I just passed my Mojave hackintosh on my surface book 2 with Clover. But my video card isn't detected properly and I can't do it.
I tried with the HD620 config.plist settings attached, but failed (I can't even run Mojave).
Any advice? Thanks
@EliteMacx86 Can you help me make iGPU of 10875h UHD630 works on my laptop?
I've tried many methods to resolve this, but all failed.
I've collected the info required and attached here.
# Help needed: how to make iGPU of 10875h UHD630 works on my laptop
## Details:
1. Laptop hardware
- Model: Gigabyte AERO-17-WB with 4K LVDS LED (3840x2160)
- CPU: Intel Core i7-10875H 2.30GHz 8 cores, 16 threads
- iGPU: UHD630, DeviceId 8086-9BC4
- Audio: ALC 255
- dGPU: disabled via ACPI aml
- LAN: Killer E2600
- WiFi: Killer Wi-Fi 6 AX1650x 160MHz Wireless Network Adapter (200NGW)
2. Os Info
- Catalina 10.15.x and BigSur 11.4.
- Loader: OpenCore 0.7.1
- Smbios: MacBookPro16,1
1. Not Working HW
- iGPU: Intel UHD Graphics 630 31 MB
- Backlight: not done
4. Working HW
- LAN: RealtekRTL8111
- WiFi: itlwm
- Audio: ALC
- USB: mapped
5. Problem
- How to make iGPU works.
6. BIOS: I've unlocked the BIOS, and done the following
- CFG Lock: Off
- DVMT: 64MB
- and other changes according to the guide
7. What I've tried
- opencore version : from 0.6.9 to 0.7.1
- mac os version: 10.15.7 to 11.4
- smbios: MacBookPro16,1/2/3/4, MacBookPro15.1
- many AAPL,ig-platform-id
- many device-id: it seeams like only the current one can display
8. My guess
- Comet Lake caused?
- Laptop ?
- Smbios ?
@EliteMacx86
I've got a unicorn laptop, XPS 13 9360 Kaby Lake with Intel UHD 620. It showed as 1 GB ram in Windows.
I have installed 12.2 via Clover, and can get to a desktop. its says I have 21 MB ram, and its is the insane native resolution of my panel, 3200x1800. I have tried a few different AAPL,ig-platform-id's but all are the same, assuming I CAN boot to desktop, it's still 21 MB
00001B59 and 60001B59 both get me to desktop in 3200x1800 no acceleration
Similar threads
qhdcjm
