Error installing macOS Catalina on Lenovo Ideapad s145 i7 1065G7
You did NOT followed the guide. The config.plist is not as per the guide.
The drivers directory is not as per the guide.
Sorry, but I have Clover v2.5 r5109...
But you told me that the drivers directory isn't as per the guide. I followed everything about that guide and I'm still having the same problem. I checked the config.plist and I also replaced with UHD630 config file.
I also tried OsxAptioFix3Drv-64 and OsxAptioFixDrv-64.
Yes, your configuration is NOT proper. It doesn't matters if you have latest Clover version. It always gets updated.
What did I do wrong?
Your files are not as per the guide. They must be according to the guide. If you have updated it, attach your PR files to check.
I know I have to install clover on pen drive, but what do I have to install here? Please, don't tell me "Follow the guide". Thanks.
Select AptioMemoryFix. This is mentioned in the guide what exactly you need to install.
You must read the guide. If you're looking for a quick recipe, i'm sorry for that. It might not be the correct place for you.
OhCamargo
