- Aug 15, 2019
- Lenovo Z500
- Intel Core i7 3632QM
- Nvidia Geforce GT-635m
- 10.13.x
- Clover (UEFI)
The latest is V14. Uninstall V11 and install V14.ok I installed it and then restarted but then it doesn't work just an icon displays wifi disconnected
here are images :
View attachment 2193View attachment 2194
I installed it I didn't install that file that shown in imageThe latest is V14. Uninstall V11 and install V14.
You need to patch the DSDT and fix USB ports.I installed it I didn't install that file that shown in image
I searched its error and someone suggests that it can be fixed by removing USBInjectAll.kext from EFI/Clover/Kexts/Other/You need to patch the DSDT and fix USB ports.
Yes, correct.I searched its error and someone suggests that it can be fixed by removing USBInjectAll.kext from EFI/Clover/Kexts/Other/
Need to find the cause. Check panic logs.I did this and WiFi Adapter now works but after some time My Mac restarts Unexpectedly
You must patch your DSDT.is this due to this fix or will be fixed after doing DSDT patch?
this is what it shows when Mac OS starts again :Yes, correct.
Looks like, you've set ""Put hard disk to sleep when possible" feature turn on in Preference / Energy." Reset it to Defaults and patch your DSDT.this is what it shows when Mac OS starts again :
panic(cpu 2 caller 0xffffff8000a288b7): "AppleAHCIDiskQueueManager::setPowerState(0xffffff80245f2000 : 0xffffff7f81b80958, 3 -> 2) timed out after 100776 ms"@/BuildRoot/Library/Caches/com.apple.xbs/Sources/xnu/xnu-6153.81.5/iokit/Kernel/IOServicePM.cpp:5302
Backtrace (CPU 2), Frame : Return Address
0xffffff81e2e63b40 : 0xffffff800033bb2b
0xffffff81e2e63b90 : 0xffffff80004734d5
0xffffff81e2e63bd0 : 0xffffff8000464f4e
0xffffff81e2e63c20 : 0xffffff80002e2a40
0xffffff81e2e63c40 : 0xffffff800033b217
0xffffff81e2e63d40 : 0xffffff800033b5fb
0xffffff81e2e63d90 : 0xffffff8000ad2aa9
0xffffff81e2e63e00 : 0xffffff8000a288b7
0xffffff81e2e63e50 : 0xffffff8000a28479
0xffffff81e2e63e60 : 0xffffff8000a3f82e
0xffffff81e2e63ea0 : 0xffffff8000a27228
0xffffff81e2e63ec0 : 0xffffff800037d7e5
0xffffff81e2e63f40 : 0xffffff800037d311
0xffffff81e2e63fa0 : 0xffffff80002e213e
BSD process name corresponding to current thread: kernel_task
Boot args: kext-dev-mode=1 dart=0 nv_disable=1 -cdfon -igfxnohdmi
Mac OS version:
19D76
Kernel version:
Darwin Kernel Version 19.3.0: Thu Jan 9 20:58:23 PST 2020; root:xnu-6153.81.5~1/RELEASE_X86_64
Kernel UUID: A8DDE75C-CD97-3C37-B35D-1070CC50D2CE
__HIB text base: 0xffffff8000100000
System model name: MacBookPro9,2 (Mac-6F01561E16C75D06)
System shutdown begun: NO
Panic diags file available: YES (0x0)
System uptime in nanoseconds: 798617598693
last loaded kext at 124096268285: |SCSITaskUserClient 422.0.2 (addr 0xffffff7f81b47000, size 45056)
last unloaded kext at 202419583548: >!AFileSystemDriver 3.0.1 (addr 0xffffff7f80c95000, size 8192)
loaded kexts:
com.realtek.driver.RtWlanU 1830.32.b15
org.rehabman.voodoo.driver.PS2Trackpad 1.9.2
org.rehabman.voodoo.driver.PS2Keyboard 1.9.2
org.rehabman.voodoo.driver.PS2!C 1.9.2
org.netkas.driver.FakeSMC 1800
as.vit9696.WhateverGreen 1.3.7
as.vit9696.Lilu 1.4.2
@filesystems.smbfs 3.4.1
>!AGraphicsDevicePolicy 4.7.2
@fileutil 20.036.15
@filesystems.exfat 1.4
@filesystems.autofs 3.0
@filesystems.ntfs 3.14.3
@AGDCPluginDisplayMetrics 4.7.2
>!AHV 1
|IOUserEthernet 1.0.1
>!AUpstreamUserClient 3.6.8
|IO!BSerialManager 7.0.3f5
>!AMCCSControl 1.13
>pmtelemetry 1
>!A!IHD4000Graphics 14.0.4
@Dont_Steal_Mac_OS_X 7.0.0
>eficheck 1
>!ALPC 3.1
>ACPI_SMC_PlatformPlugin 1.0.0
>!A!IFramebufferCapri 14.0.4
>!A!ISlowAdaptiveClocking 4.0.0
@filesystems.apfs 1412.81.1
>!AVirtIO 1.0
@filesystems.hfs.kext 522.0.9
@!AFSCompression.!AFSCompressionTypeDataless 1.0.0d1
@BootCache 40
@!AFSCompression.!AFSCompressionTypeZlib 1.0.0
>!AAHCIPort 341.0.2
@private.KextAudit 1.0
>!ARTC 2.0
>!AACPIEC 6.1
>!AACPIButtons 6.1
>!AHPET 1.8
>!ASMBIOS 2.1
>!AAPIC 1.7
>!A!ICPUPowerManagementClient 222.0.0
$!AImage4 1
@nke.applicationfirewall 303
$TMSafetyNet 8
@!ASystemPolicy 2.0.0
>!A!ICPUPowerManagement 222.0.0
|EndpointSecurity 1
>!AGraphicsControl 4.7.2
@kext.triggers 1.0
|IOAVB!F 800.17
>!ASSE 1.0
>!ASMBus!C 1.0.18d1
@!AGPUWrangler 4.7.2
>IOPlatformPluginLegacy 1.0.0
>!AHDA!C 283.15
|IOHDA!F 283.15
>IOPlatformPlugin!F 6.0.0d8
|IOAccelerator!F2 438.3.1
@!AGraphicsDeviceControl 4.7.2
|IOGraphics!F 569.4
|IOSlowAdaptiveClocking!F 1.0.0
@plugin.IOgPTPPlugin 810.1
|IOEthernetAVB!C 1.1.0
|IOSkywalk!F 1
|IO!BHost!CUSBTransport 7.0.3f5
|IO!BHost!CTransport 7.0.3f5
|IO!B!F 7.0.3f5
|IO!BPacketLogger 7.0.3f5
>usb.networking 5.0.0
>usb.!UHostCompositeDevice 1.2
>usb.!UHub 1.2
|IOAudio!F 300.2
@vecLib.kext 1.2.0
|IOSerial!F 11
|IOSurface 269.6
@filesystems.hfs.encodings.kext 1
|IOAHCIBlock!S 316.80.1
>usb.!UHostPacketFilter 1.0
|IOUSB!F 900.4.2
|IOAHCI!F 290.0.1
>usb.!UEHCIPCI 1.2
>usb.!UEHCI 1.2
>usb.!UXHCIPCI 1.2
>usb.!UXHCI 1.2
>!AEFINVRAM 2.1
>!AEFIRuntime 2.1
|IOSMBus!F 1.1
|IOHID!F 2.0.0
$quarantine 4
$sandbox 300.0
@kext.!AMatch 1.0.0d1
>DiskImages 493.0.0
>!AFDEKeyStore 28.30
>!AEffaceable!S 1.0
>!AKeyStore 2
>!UTDM 489.80.2
|IOSCSIBlockCommandsDevice 422.0.2
>!ACredentialManager 1.0
>KernelRelayHost 1
>!ASEPManager 1.0.1
>IOSlaveProcessor 1
|IOTimeSync!F 810.1
|IONetworking!F 3.4
|IOUSBMass!SDriver 157.40.7
|IOSCSIArchitectureModel!F 422.0.2
|IO!S!F 2.1
|IOUSBHost!F 1.2
>!UHostMergeProperties 1.2
>usb.!UCommon 1.0
>!ABusPower!C 1.0
|CoreAnalytics!F 1
>!AMobileFileIntegrity 1.0.5
@kext.CoreTrust 1
|IOReport!F 47
>!AACPIPlatform 6.1
>!ASMC 3.1.9
>watchdog 1
|IOPCI!F 2.9
|IOACPI!F 1.4
@kec.pthread 1
@kec.Libm 1
@kec.corecrypto 1.0
is needed more data?
ok but I haven't change anything it was set by defaultLooks like, you've set ""Put hard disk to sleep when possible" feature turn on in Preference / Energy." Reset it to Defaults and patch your DSDT.
Patch your DSDT. Provide your PR files.ok but I haven't change anything it was set by default
