Battery indicator not working in catalina
Aryan223991
Hp probook x360 440g1
I5 8250u
Uhd 620
10.13.x
Hello gurus, i successfully installed the catallina 10.15.3, my audio, graphics, brightness working but neither battery indicator nor trackpad(works but not showing up in system preference due to battery issue) works... Pls help me i tried every website from olarilla to tonymacx none of them reply to my query... U r my last hope....
Here are few issues.
  • ACPI is not patched.
  • The configuration is not as per the guide.
Sir, the attached file are my initially generated dsdt and they are untouched i already patched one for audio, brightness but neither of rehabman bat patches work on my laptop.
Follow the guide above and create a new configuration. Boot using that and attach your PR files.
Sir i followed olarilla guide and patch my dsdt. But stuck at this
Now at this pls help me
Pls help me... Sir
Thank
No Problem Reporting files attached. Unless you follow the guide, attach the PR files, i cannot help you at all. If you're looking for a cooked meal here, it's not the correct place. Here, you need to cook the meal for yourself. I can guide you only.
Thank u sir for ur reply..... I successfully complete my hackintosh build and everything works like charm..Always thankful to u
Thank
Mark solved.
alvarg82
