Lenovo ThinkPad E520
Did you mean this one? In your guide?
Can you send me the link? There are a lot of accounts named Chris on GitHub.
I checked it today. But Chris only has work for Mojave and Catalina. HS already supports Intel HD 3000. Attach your PR files to check.
So basically my entire clover boot loader folder but without the serial numbers?
Laptop: Lenovo ThinkPad Edge E520
CPU: Intel Core i3-2330M 2.20GHz.
Chipset: HM65.
Graphics: Intel HD Graphics 3000.
Resolution: 1366x768.
Bootloader: Clover (UEFI).
Clover bootloader folder (without serial numbers) attached below.
Chipset: HM65.
Here are some of the issues.
  • The config.plist is not as per the guide.
  • Remove BOS directory from the drivers folder.
  • No kextcache output attached.
I am using the config that I found online and its the only one thats working.
You should NOT use someone else's files.
Adri114bs
