Lenovo ThinkPad E520
ShonP40
Gigabyte GA-Z270-HD3P
Intel Core i7-7700K
AMD Radeon RX 6600 XT
15.x
Hi,
I've been trying to get the MacOS installer to boot up on my laptop but for some reason when it boots up, all I see is a fading black to grey screen and I can see every pixel on the screen.
Specs:
Intel Core i3-2330M
Intel HD Graphics 3000
4GB RAM
I followed the installation guide and used RehabMan's config_HD3000_1366x768.plist config file.
If I remove nv_disable=1 I'll get a black screen
Ok, I managed to boot using the files (attached) that I found here.
Its installed but I have one problem: The GPU is showing up with 3mb of RAM.
When I remove nv_disable=1 the laptop gets stuck at Waiting for DSMOS...
By removing the AppleIntelFramebufferCapri, AppleIntelHD3000Graphics and AppleIntelSNBGraphicsFB kexts from clover and removing nv_disable=1, MacOS boots up but it still shows 3MB RAM on the GPU.
Hi,
Specs:
Intel Core i3-2330M
4GB RAM
Please note that you should use your own files. Do NOT mention links of another sites. Check the Rules.
Install it normally. Follow the guide here:
To fix Intel HD Graphics 300, follow the guide here:
But I am using MacOS High Sierra, not Mojave...
The same is for High Sierra, choosing another installer. I guess HS already supports Intel HD 3000.
Wdym another installer?
I followed your High Sierra installation guide
unreal15
