Intel HD4000 and Radeon R7 250x (HD7000) simultaneously
naquaada
Gigabyte GA-Z77M-D3H
Intel 3770S
Radeon R7 250X
10.14.x
  1. Clover (Legacy)
Hello,
I'm an old-school OSx86 user and I'm still using Mavericks. Why? Because it works. The Clover setup I'm using is probably 10 years old, but it works fine on many different boards. I'm also using Legacy BIOS, never had a reason to switch to UEFI. I'm only doing desktop publishing, graphics work and audio editing, so I don't need anything newer. If somebody is requiring help with older hardware or software, ask me. I also have old software versions patched for use with modern macOS versions. I also have version 148 of Firefox Dynasty. The GitHub page disappeared from one day to another.
Future plans: I've actually done a new Mavericks installation and now I'm on creating a fresh installation of Mojave. I have hardware which has 32 bit drivers only, so I always want to have an older OS X version available. There's also some great software which never got a 64 bit port. On this hardware I'll try Monterey too. To avoid conflicts I have all kexts in S/L/E. No kexts in Clover. Mojave is installed on an HFS+ partition.
Hardware: Gigabyte GA-Z77M-D3H, Core I7 3770S, 32 GB RAM, Sapphire GPRO 4200 graphics card (4x Mini-DP, 4 GB VRAM, ID 0x682B), Broadcom WLAN/Bluetooth, Asus U3S6 (Combo card with Marvell SATA and NEC USB3) and a Creative Audigy 2 ZS PCI soundcard. All components are fully working.
Recently I got an Asus PA32QCV 6k monitor. It's great, but this monitor wasn't made for user who sometimes need to go into BIOS or open the boot menu. It takes endlessly until it shows an image. So I wanted to use the Intel HD4000 for an additional iiyama monitor which is starting faster. It has VGA, DisplayPort and HDMI.
On Mojave I got a working GPRO 4200, the HD4000 is just showing the text from the boot sequence, no macOS display. But it is the main display, the GPRO 4200 screen has no menu bar or Dock. OS X crashes at boot if IntelFramebufferCapri.kext is installed. If I remove it, I have working dual monitor, but the HD4000 has no QE/CI, visible on the grey menu bar.
The HD4000 is connected to IGFX, the GPRO 4200 at PEG0, PEGP, GFX0, depending on the Clover settings. So I guess the problem is either in AppleIntelFramebufferCapri or the display name settings. Lilu and WhateverGreen is installed and loaded. But I have to admit that I don't see a difference if the kexts are loaded. The system also works without them. I'm also still using FakeSMC, VirtualSMC never worked for me.
Here's the Clover plist. I also added a photo with the Mavericks crash at boot.
Greets, naquaada.
  • config.plist
    config.plist
Hello,
Greets, naquaada.
  • Add -lilubetaall to enable Lilu and all loaded plugins on unsupported os versions (use very carefully).
you do not need that argument:
you also should not be injecting Intel either...
you may want to add in your Intel Graphics properties:
https://github.com/acidanthera/WhateverGreen/blob/master/Manual/FAQ.IntelHD.en.md
That was a good beginning. I now have the system working with two monitors and IntelFramebufferCapri.kext is loaded with 1024 MB VRAM. The HD4000 is connected from HDMI output to and HDMI input, so there is no conversion. HDMI Audio out also works with VoodooHDA, but I have to set it to 8 channel 16 bit.
Still, AppleIntelHD4000Graphics.kext is not loaded. Maybe it's a problem because my Intel graphics ID is 0x01620009 which is nowhere listed. You can see it in the screenshot of system profiler. Actually I've tested 0x01620005 and 0x01620009.
There's also a long boot pause, then I get this message:
kernel[0]: DRMStatus: iTunes/Apple Store Content Access Problem. Content playback may be disabled on this computer. You can continue to use the machine, but you should contact an Apple support representative. ErrorCode: 8877652
Hello,
Greets, naquaada.
You want to use the HD4000 as a main GPU or just for QSV?
What is QSV? Intel Quick Sync Video? I never heard that term. I know something that macOS uses IGFX for video decoding and some DRM stuff, but because I had the Intel HD4000 always disabled in BIOS I never cared about it.
Actually I want to use the HD4000 as a monitor which is starting immediately to get easier in the BIOS and the bootloader. If I turn on or reset the computer, the Asus monitor connected to the GPRO 4200 shows the first display as Clover is already counting down the boot timout. That's why I have to set it to 10 seconds.
In the BIOS I have to set IGFX as 'Init Display First' so it is immediately activated. In OS X it was planned work as a second monitor. If there are other uses for it...
Yes, correct. You'll have to patch framebuffers
Similar threads
angelkiller
