Tryting sequoia ( ryzen 3600, 1070 ti )
Ezger
msi b450m mortar
ryzen 5 3600
msi gtx 1070 ti gaming x
i just joined this community 5 mins ago, first of all i would like to declare sincere gratitude for those who provide this type of hacks, without you its impossible for common user to make this function properly, so thank you.
i am determined to install MacOS on my system:
- ryzen 5 3600
- msi 1070 ti gaming X
- 16gb ram
- msi b450m mortar
my desire is to install Sequoia since its the current sweet spot supported OS, i have seen some people managed to make it work.
first try, i followed a video guide + Dortania
result:
while creating the EFI through the guide, i noticed some difference in the Config file,
- ryzen 5 3600
- 16gb ram
- msi b450m mortar
result:
boot verbose to see what the issue is
also not much support for msi 1070 ti gaming X
and you want to remove all other drives from your machine, just have the blank drive to install mac on
Reactions: Ezger
i know am trying something incompatible, the Admin managed to run 1070 on Sequoia with what he said 'limited support'
if the 'limited support' can run the program that i need without issues and enough performance, my goal would be achieved.
if not i will just try Tahoe or high sierra ( they both support my hardware )
i managed to make a functional bootable USB, but now am stuck at this
after i chose the language and around 30% installation ,
you will have no hardware acceleration with your incompatible video card, last supported version was High Sierra
я только что присоединился к этому сообществу 5 минут назад, прежде всего я хотел бы выразить искреннюю благодарность тем, кто предоставляет хаки такого типа, без вас для обычного пользователя невозможно правильно выполнить эту функцию, поэтому спасибо.
я решительно настроен установить MacOS на свою систему:
- райзен 5 3600
- msi 1070 ти гейминг X
- 16 гб барана
- миномет msi b450m
мое желание - установить Sequoia, поскольку ее нынешняя сладость поддерживает ОС, я видел, как некоторым людям удалось заставить ее работать.
с первой попытки я следил за видеогидом + Дортания
результат:
[МЕДИА=youtube]2uSFk9yzJ3Q[/МЕДИА]
ф. в заповеднике EFI стал одним из самых известных людей в фаиле Кониге
@Mark&
Posting
  • Use English only. English is a global language and you need to post all the topics, replies, signatures, profile, name, comments in English only. Do not use any other language. Use of any other language will lead to removal of your post/messages.
i did actually , i tried again with FULL drive erase
PC automatically boot from MacOS installation and it kept looping like 10-12 times in the same process
so am looking for something else, perhaps play with the config file , idk
nicolacibin08
