Random screen glitch and freeze on Ventura (and Sequoia)
pct
Gigabyte B760M DS3H DDR4
Intel Core i5-12600K
SAPPHIRE PULSE RADEON RX 570 4G
Hi
I have succesfully installed Ventura 13.7.8 on the following hardware :
Gigabyte B760M DS3H DDR4 bios F14
Intel Core i5-12600K 12th Gen Alder Lake
RAM 32Go : Crucial 16Gb 3200MTS x 2
Radeon Sapphire Pulse RX 570 series 4Gb
Sandisk SDSSDHP256G : Ventura 13.7.8
Sandisk SDSSDA120G : MacOS
Right after the install on Ventura, everything was ok but some time the screen glitch with squared pattern (see picture attached). It could be :
- with screen saver off and disk suspend off, after a variable period of time of inactivy (not touching keyboard or mouse),
- with screen saver on, once the screen saver is started, I move the mouse and get the password screen, then it freeze just after.
The PC is still alive as I can connect via ssh and run some commands, just the screen get scrambled. If I try to restart properly vi a shutdown -h now, it quit the remote session, I can see the disk led flashing for few seconds but the PC does not stop : I have to hard stop it.
I then have made bunch of tests and adjustements :
1/ build my own SSDT files, the one I now use both on Ventura and Sequoia.
2/ build my USB MAP with USBToolbox on Windows. I also added XHCI-unsupported.
3/ change the model to iMacPro1,1 as per the recommandation in the thread I found here on the forum "ASUS PRIME Z690M-PLUS D4 - i9 12900KF - 128GB RAM - AMD RX 5700XT - Thunderbolt HotPlug - OpenCore"
Now, I would say it does work pretty well on Ventura, including screen saver/shutdown and sleep, but, while quite rare, it could still happen it freeze after a random period of time or run ok for hours.
On Sequoia, it systematically glitch and freeze very quickly after the login screen, while it has the same EFI.
What worries me is the fact it's random, I have not been able so far to find what could raise the freeze on Ventura, and quite surprise by the systematic freeze on Sequoia.
I have the following questions:
1/ The MB has a Intel Raptor Lake USB 3.2 Gen 2x2 (20 Gb/s) XHCI Host Controller Id 8086:7A60. Even when I load XHCI-unsupported kext, when I check in hackintool, it still says unknown device (see picture attached) : is this normal (just cosmetic impact) or does it impact the USB behaviour ?
2/ I have now selected iMacPro1,1 after reading the thread here (see above) with your recommandation of iMacPro 1,1 for Intel Alder Lake i3 and i5, and MacPro 7,1 for Intel Alder Lake i7 and i9 : this is the first time I saw this recommandation, usually, both are recommanded for Alder Lake without any split between the 2 Mac type based on the model of Intel Core : can your explain why this ?
3/ as I get apparently a freeze of the WindowServer, I had check the vBIOS of the Radeon but it appears it's the stock one and BTW the card is running well under Windows 11. Then I read it could have a link with USB, but I am not sure of this.
I have attached my 2 EFIs, would appreciate if someone could spent some time to check them to see where could be the root cause.
Thanks Phil
  • EFI ventura.zip
    EFI ventura.zip
  • EFI Sequoia.zip
    EFI Sequoia.zip
After several tests on Sequoia, it appears that if I disable all screen saver and sleep, it keep running.
As soon as I put even just the screen saver (not talking sleep), soon or later it freeze
Yes, is normal.
Preference due to frequency vectors. Still, iMacPro1,1 stands best so stick to that.
Are you using stock VBIOS?
The picture you attached, happens mostly due to memory corruption. It could be your RAM or the memory chips on the GPU (aka GPU itself).
EFI is not as per the guide.
Reactions: RickyThaDragonjr
"The picture you attached, happens mostly due to memory corruption. It could be your RAM or the memory chips on the GPU (aka GPU itself)."
Is there a way to do an hardware test of the card to detect an hardware failure ?
Thanks
"Are you using stock VBIOS?
Yes. I asked Sapphire who send me the stock VBIOS, uploaded to the card with same result.
I also could suspect a hardware failure but :
1/ how can it be tested by software to be sure it is this ?
2/ the same PC is also booting Windows 11 and has never never freezed, strange no ?
Thanks
You can use memtest to test your RAM.
Then, it could be the BIOS or the EFI. Attach the EFI to check.
I have forgot to share that the same hardware boot W11 on a second disk and it run perflectly well, never ever had any freeze.
If there is an hardware failure, I do not understand why it run so well with W1 and why it freeze with Sequoia.
memtest test only the PC RAM, not the GC VRAM ?
When your say it could be the BIOS, you mean the Gugabyte MB BIOS or the AMD GC Bios ?
My latest EFI attached.
Thx
I had similar thing happen to me with X299, it would work fine, great , normal and then all of a sudden frozen. what mine turned out to be is there are three fans on the front of mine looks like a huge old graphics card, anyway there are some tubes running from it and going to the processor CPU Area. Im new to desktops, just recently got into that so it was a unchartyed water for me but my problem was this there was a wire that wasnt attached underneath where all the other wires are harnessed it was a "SATA pORT LOOKING TYPE PLUG, I HAD SEEN IT AND THOUGHT OH THATS SATA thats not it. So i contacted a friend of mine in Pennsylvania and told him what was up and did a video chat showing what the symptoms were and he said dude thats your cooling stuff thats goes thourgh those tubes its a water cooler he saud and so i plugged that in. Problem solved. You might want to check that on y6ou end
May or may not be the problem. I d say Its worth a quick look to rule it out
Thx
Your EFI is not as per the guide. Problems are expected.
R00TEAD0
