Intel HD Graphics 630 only 7mb
This simply means macOS cannot find the root device.
I'm sorry, please! It turns out that the patches had to be removed, without them the laptop loads, but without the screen backlight.
Could you please specify what patches you are referring to?
It was written in your instructions to remove it, but here:
  • GFX0 to IGPU
  • PEGP to GFX0
  • HECI to IMEI
  • MEI to IMEI
  • HDAS to HDEF
  • B0D3 to HDAU
  • GFX0 to IGPU
  • PEGP to GFX0
  • HECI to IMEI
  • MEI to IMEI
  • HDAS to HDEF
  • B0D3 to HDAU
Yes, these must be removed. Attach your EFI to check
Why are you using AirportItlwm and itlwm together?
I'm telling you that I'm bad at hackintosh and thought I needed to add two
No, choose one. Also, have you injected the correct EDID? There is a usr who had similar issue. What's the WEG version?
Okay, I'll choose one. But it worked perfectly on previous versions of macOS, and what is WEG?
WEG is WhateverGreen. Use v1.6.5 and then check
Similar threads
adamnor206
