HP Pavilion G6 1250ej
Everything works except WiFi, Bluetooth, Brightness control and for some reason MacOS doesn't map my keyboard correctly and uses the alt key as the command key and the command key as the alt key.
No PR files attached. What WiFi model?
What do you mean PR files?
What problem reporting files do you want?
And this is the WiFi+Bluetooth card that this laptop has: Broadcom BCM94313HMGB.
So, is my WiFi card supported? If yes, what kext/s do I need to use?
I just checked HP’s manual and looks like the only other WiFi+Bluetooth card it supports is the Atheros AR5B225.
So, will any of them work on MacOS?
(Broadcom BCM94313HMGB and Atheros AR5B225).
qhdcjm
