Intel HD Graphics 630 only 7mb
SlavaUdd85
i7-7700HQ
MSI GV62 7RD Intel Core i7-7700HQ HD Graphics 630 after applying patch it has become 1536 MB but black screen HDMI working please HELP!! sorry for bad english
Which patch?
I did it in Hackintool, but it works fine on Sierra, and the higher versions are already in the black screen.
Could you please clarify which patch you're referring to? If you're having a black screen, make sure the framebuffer patching is correct. In some cases, you may need to add igfxonln=1 flag.
I chose everything correctly, checked everything, connected the laptop with an HDMI cable, a picture and transparency appeared in the dock, and the screen was all black and the boot argument that you wrote was written automatically
here I made a patch for hd 630 kaby lake now on sierra because everything works fine here
The same patch isn't working on the new macOS version? If so, what's the current macOS version you're having black screen issue?
I've checked that the patch is working on High Sierra and the black screen is starting from Mojave to the latest
The CPU model is the same as in your profile?
Similar threads
alvarg82
