Internal WiFi not working
JullianDev
Acer Aspire A514-52 WL Sneezy_WC V1.04
Intel(R) Core(TM) i5-8265U CPU
Intel UHD 620
10.13.x
Hi,
Yesterday I succesfully installed macOS Catalina on my laptop. Now there is a couple of problems:
  1. Wifi is not working, there is not even a function for wifi, internet cable also doesn’t work.
  2. Sound is not working
  3. Mousepad (the one build in the laptop) is not working
  4. I accidently removed Windows boot manager( i still have my data)
Another question, how can i install that i’ t will start the macOS installation without going to boot everytime again?
Hope someone who can help me with this. In case needed my laptop specs:
Laptop brand: Acer
Model: Aspire A514-52
Motherboard: WL Sneezy_WC V1.04
CPU: Intel(R) Core(TM) i5-8265U CPU
Processor:
Graphics card: Intel UHD Graphics 620 (something with Family?)
RAM: 8GB
BIOS-version/date: Insyde Corp. V1.04, 9-5-2019
SMBIOS-version: 3.0
BIOS-mode: UEFI
Hi,
You should open each specific thread for each particular issue.
Have you replaced the WiFi Card with a compatible one? What's your Ethernet chip? Attach a screenshot of DPCI Manager>PCI List
What's the Codec?
What's your Trackpad vendor and model?
Do you need Windows boot manager or?
Can you explain it more clearly?
What's the Codec?
Hi,
Okay, i will open a thread for each problem.
let we focus on the Wifi problem then is this thread because its the most annyoing problem.
i didn’t replace any wifi card, i also don’t know what my internet chip is. And how can I acces DCPI manager? I attach some screens what i think it is. Also attached a screenshot of what i found of the laptop with ethernet (hope that it is)
Better.
DPCI Manager is an Application. Download it and run it. Attach a screenshot. If you haven't replaced the WiFi Card, it's probably from Intel which is unsupported and will NOT work. Consider a WiFi replacement.
Better.
Can you send me a download link of that please?
Hi, see attachment for screen of PCI List
You've Qualcomm Atheros which is not supported. Replace it with a compatible card.
How can i replace that? And is there a possible way to get internet cable working?
gopon_user
