Post installation problem which are unable to be fixed in macOS Sonoma!!!
How can i disable nvidia dgpu if i dont have an option in bios i have no option in my laptop bios regarding disabling dgpu all i can do is disable the igpu in windows
System Information not attached. About This Mac>System Report
The dGPU (NVIDIA) is not disabled properly. You can only verify the VRAM either via BIOS or via Windows/Linux. How did you verify that it has 512MB VRAM?
IOReg is not attached.
It will be unknown until the Graphics acceleration is fixed. Are you using the latest NootedRed.kext?
is this IOReg if yes what to do with it and if no then send me the link to download it
I am also sharing system information in the screenshots
  • IORegistryExplorer-SLRID_v10.6.3.zip
the procedure of disabling the Nvidia gpu is really complex and going out of my head is there any other way to do something its so annoying and complex
this
this is totally complex and I cannot understand at all and its for Intel-Nvidia or Intel-AMD meanwhile I have AMD + Nvidia
Its because you're not paying attention. If the DSDT/SSDT method sounds complex for you, why not use the Boot Arg or Device Properties method to disable the dGPU?
i
i am thinking to make the efi on my own i was using someone other efi but this time i will make my own tell me step by step so that i can make new efi and this time i will load macOS sequoia
Of course you can do that. But you still have to configure the post installation.
I had to remove the sonoma cuz it currupted my windows but now i am going to reinstall it using sequoia and this time i will make proper efi
Now i am making my own EFI for macOS Sequoia and i got this MACH REBOOT error i am attaching my EFI tell me the problems in my own made EFI via google drive here as its not uploading in your site due to file size exceed problem and this problem has and need to be fixed and btw i also have my audio codec with me but where to put in tell me that also and i am sharing my iGPU VRAM details also
  • audiocodec.plist
    audiocodec.plist
zazau197
