Post installation problem which are unable to be fixed in macOS Sonoma!!!
ZeroTwo
Asus ROG Strix G15 2021
AMD Ryzen 9 5900HX
RTX 3060 Laptop GPU
  2. OpenCore (Legacy)
  1. Other
My PC Specs:-
Laptop- ASUS ROG STRIX G513QM 2021
Processor- AMD Ryzen 9 5900HX 330ghz
RAM-16GB DDR4 Ram
IGPU- AMD Vega iGPU
GPU-Nvidia RTX 3060 Laptop GPU 6GB
SSD-1TB
WIFI- Intel AX210 WiFi 6e and Bluetooth 5.3
Post Installation Issues:-
--> Wifi Working but bluetooth not working
--> AMD iGPU not working even after adding Nootedred.kext
I tried using nootedred kext to try to enable this but the problem I get is either while restarting the Mac the progress bar got stuck which doesn't let me boot into macOS but when I disable it and use whatever red then it works but graphics doesn't get enabled
--> my laptop keyboard not working but touchpad working even after adding VOODOO
--> no sound audio at all
--> my keyboard is rgb and I cannot control my rgb to one color
I have to disable 2 more kext as you can see in my screenshot whenever I enable any of those kext and restart the device the progress bar gets stuck again please help me fix the above problem I tried even adding the kext file still doesn't fix the problem help me fix the above problem
My PC Specs:-
RAM-16GB DDR4 Ram
IGPU- AMD Vega iGPU
SSD-1TB
Duplicate of
BT requires additional steps. Did you follow the guide?
Whateverred is depreciated. NootedRed is what you need to use.
Keyboard is not working or the Touchpad?
Did you follow guide to implement the audio?
Set from Windows and then use it on Mac.
WhateverGreen should not be used with NootedRed.
@ZeroTwo You can use a single thread and wait for the response. You don't have to create separate threads simultaneously.
1. I tried everything in bluetooth even having all Intel Bluetooth firmwares also but whenever I turn on the bluetooth it does not show any pair device and within few seconds it automatically turns off
2. I noticed whenever I enable NootedRed.kext and reboot the laptop it gets stuck on the apple logo with a half progress bar completed everytime
3. my touchpad is properly working but not the keyboard I am using external keyboard for this
4.no I used apple ALCU.kext for this
5.ok I will setup rgb in windows
6.i deleted the whateverRed and use nootedred only but doesn't work at all instead it stuck it into the apple logo or boot screen and its really getting annoying I wasted my whole day fixing these issues but nothing working at all
please help me tell me something I can do to use Hackintosh in peace I am attaching my EFI link via drive as I cannot upload big size file here
MY EFI here
please tell me all the issues in the efi and what to be fixed in order to use my Hackintosh in peace even if I update it to sequoia
Attach System Information.
Attach EFI. What's the VRAM in your BIOS?
Are you using VoodooPS2 kext?
ALCU is for USB based Audio onboard audio. What's your Audio Codec?
Screen model might be an issue or may require EDID patching. What's the VRAM in BIOS?
MY EFI here
Zip and then attach the EFI. Also, what macOS version you have currently installed?
I am unable to attach EFI file here as I said its saying file size exceed its 66mb big due to which I am unable to send the efi to you that is why I attached drive link here
whenever I logged into my bios I see risen 9 5900hx with radeon Vega 8 graphics which is 512 mb VRAM inbuilt iGPU
I am using voodooPS2 kext which enables using of touchpad but not keyboard so I am using external keyboard to use the hackintosh
moreover I just sent you the whole thing with screenshot attached which shows all kext I am using
I am using macOS Sonoma 14.7.1
and the display is my own laptop 300hz display which this Hackintosh consider as unknown display you can tell me about EDID patching what it does and how can I fix this
As you can see from the picture of my laptop due to nootedred its stuck on the apple logo with progress bar stuck and i am also unable to update the hackintosh to sequoia also as it just shows apple logo only and stuck
AS YOU CAN SEE IN THE SCREENSHOT I AM UNABLE TO UPLOAD MY EFI IN YOUR SITE SO I UPLOADED IT ON DRIVE, YOU CAN DOWNLOAD IT AND CHECK MY EFI FILE
System Information not attached. About This Mac>System Report
The dGPU (NVIDIA) is not disabled properly. You can only verify the VRAM either via BIOS or via Windows/Linux. How did you verify that it has 512MB VRAM?
IOReg is not attached.
It will be unknown until the Graphics acceleration is fixed. Are you using the latest NootedRed.kext?
By
How can i disable nvidia dgpu if i dont have an option in bios i have no option in my laptop bios regarding disabling dgpu all i can do is disable the gpu in windows
When i checked the device manager i saw 2 gpu one is nvidia one and other is amd vega gpu and i checked there it was 512mb vram one so thas how i know
And when i search it for nootedred latest version it took me into github where alots of files are there but no kext file let me show u via screen shot
Nootedred link —> https://github.com/ChefKissInc/NootedRed?tab=readme-ov-file
chirag11122
