[SOLVED] Need help with installing.
OMG!! It worked for me. Thank you very much. There is only one thing..
When i’m selecting the hard disk i want to install it on it says:
They are s.m.a.r.t-erros on this disk. This disk has hardware problems and can not be restored
what can i do to fix this?
Attach a error screenshot.
See attachment for the screenshot
This is SMART error which simply means that the drive is failing. Backup your data, if any and replace the drive with a new one.
So that means I cannot install macOs Catalina on the drive and need to buy a new drive for that?
Hi, everything works fine, there is only one big problem..
my wifi connection is not working. How can I fix this?
edit: maybe better to say that there is not even a function related to wifi or internet cable.
Also noticed that:
  1. Sound is not working
  2. Mousepad (the one build in the laptop) is not working
Another question, how can i install that i’ t will start the macOS installation without going to boot everytime again?
Also noticed that:
Off-topic. Create a separate thread for the rest of the issues.
bmk07
