[SOLVED] Need help with installing.
In the guide everytime it's showing "drivers64UEFI" or at the end of the drivers "-64"
It's not showing at me, but I don't think that will be a problem right?
Can you please be more precise and clear?
Hi,
I followed the guide and did everything it says, but still no succes. It freezes again. I took a picture when it freezes and uploaded it.
No PR files attached.
In the guide everytime it's showing "drivers64UEFI" or at the end of the drivers "-64" (See attachment 1)
Also there is a folder /EFI/Clover/drivers64UEFI
And for me when installing the drivers i can't select any drivers with -64 and also I don't have the folder drivers64UEFI
For the new Clover Bootloader, it's drivers/UEFI (For UEFI boot)
The config.plist is modified. Remove the modifications from the Graphics tab. Your Laptop needs RTC patch.
Add the following patch in the Acpi section of your config.plist in the renames.
Comment: Fix 300-series RTC Bug
Find* [HEX]: A00A9353 54415301
Replace*[HEX]: A00A910A FF0BFFFF
I'm sorry i don't understand, my english is not that good. What did you mean with PR files?
Nevermind, i will upload clover folder after i eat.
Here is my clover.zip file. Sorry for using external links!
OMG!! It worked for me. Thank you very much. There is only one thing..
When i’m selecting the hard disk i want to install it on it says:
They are s.m.a.r.t-erros on this disk. This disk has hardware problems and can not be restored
what can i do to fix this?
Alisson de Santana
