Help: macOS Sequoia - Installation Problem (Prohibited Sign 🚫 During Installer Boot)
Hurling7051
Gigabyte H410M S2 V3 (BIOS F10b - Jun 10, 2025)
Intel Core i3-10105
Intel HD Graphics 630
15.x
  • 🖥️ System Information:
    ItemDetails
    PC ModelHP EliteDesk 800 G2 SFF
    CPUIntel Core i5-6500T (Skylake-S, Socket H4 LGA1151)
    MotherboardHP 8054 (Intel Q170 chipset, KBC Version 05.39)
    BIOSHP N01 Ver. 02.60 (12/15/2022)
    RAM16GB DDR4 (2x8GB): Crucial PC4-21300 + Kingston PC4-17100
    iGPUIntel HD Graphics 530 (Skylake-S GT2)
    Storage250 GB (ssd)
    BootloaderOpenCore (latest)
    ❗ Problem Summary:
    I'm trying to install macOS Sequoia on my HP EliteDesk 800 G2 SFF. I can get to the OpenCore boot picker without any issues, but as soon as I select "Install macOS Sequoia," I immediately get a black screen with a prohibited sign 🚫. This happens before the installer even begins — it's not the typical "black screen after the first reboot" issue that some others have encountered.
    🧩 Boot Sequence + Errors:
    1. Boot to OpenCore picker → Works ✅
    2. Select "Install macOS Sequoia" → Fails ❌
      • The screen flashes briefly, then I see:
      • Code:
        OCS: No schema for LegacyEnable at 2 index, context <NVRAM>
        🚫 Prohibited sign
        OCB: StartImage failed - Aborted
  1. Photos attached: Images
    • OpenCore Picker
    • Black screen with prohibited sign
    • Boot log with error messages
🔎 Diagnosis:
SymptomMeaning
OCS: No schema for LegacyEnableMinor warning — leftover/obsolete key from previous OpenCore versions. Harmless.
🚫 Prohibited SignCritical — the installer cannot find a valid environment or missing drivers.
OCB: StartImage failedOpenCore failed to load the macOS installer image properly. Fatal error.
🛠 Possible Causes + Solutions:
AreaAction
Config.plistRemove the LegacyEnable key. Validate the config using ProperTree or OpenCore Configurator.
SMBIOSUse a modern SMBIOS (recommend: iMac17,1).
SecureBootModelSet to Default or Disabled under Misc > Security.
KextsMake sure you're using the latest versions: Lilu, WhateverGreen, VirtualSMC, AppleALC, NVMeFix, etc.
UEFI DriversEnsure you're using: OpenRuntime.efi, OpenCanopy.efi, and HfsPlus.efi.
ACPILoad basic SSDTs: SSDT-PLUG, SSDT-EC-USBX, SSDT-AWAC (for Skylake timer fix).
USB MappingSequoia enforces stricter USB mapping. Build a proper USB map using USBToolBox.
Installer USBDouble-check that the USB was built correctly: GPT format, APFS volumes, and a verified installer.
📢 Extra Notes:
  • macOS Sequoia may be more sensitive to outdated settings than older macOS versions like Monterey or Ventura.
  • Skylake graphics (Intel HD 530) should work fine, but ensure WhateverGreen.kext is up-to-date.
  • If using only iGPU (Intel HD 530), make sure the AAPL,ig-platform-id is correctly injected for Skylake (0x19120000 or 0x19160000, depending on the specific model).
  • Some HP desktops may require minor quirks to get USB or Audio functioning properly — these can be addressed after the OS is installed.
💬 Can You Help?
If anyone has advice or suggestions for resolving this issue, I would greatly appreciate it! I’m happy to share my config.plist and additional details about my drive and partition setup to assist with troubleshooting.
Thanks in advance for your help! 🙏
    ItemDetails
    Storage250 GB (ssd)
    ❗ Problem Summary:
      • Code:
        🚫 Prohibited sign
    • OpenCore Picker
🔎 Diagnosis:
SymptomMeaning
AreaAction
📢 Extra Notes:
💬 Can You Help?
Attach the complete EFI you're using to boot.
still error :
Regarding the error, add SSDT-SWAC-DISABLE.aml and then check.
after going through the video
Here the link for new efi that i made according to the video file
still error :
Still not as per the guide. Important kexts are missing and ACPI Quirks are not correctly configured.
Also, as macOS Sequoia is not supported SKL CPUs, you'll have to use a different SMBIOS for macOS Sequoia. You can use iMac18,2 or 18,3.
After your reccomdeation i move to new machine
System Specs:​
ComponentDetails
MotherboardMSI H110M PRO-VH PLUS (MS-7A15)
ChipsetIntel H110 (Skylake PCH-H)
CPUIntel Core i3-7100 (Kaby Lake, LGA1151)
RAM8GB DDR4 2400 MT/s (M4U08S681LJJJ43-12)
iGPUIntel HD Graphics 630 (Kaby Lake-S GT2)
BootloaderOpenCore (latest, presumably 0.9.9+)
BIOS VendorAmerican Megatrends
BIOS Version1.C0 (UEFI Capable)
BIOS Date06/16/2018
Super I/ONuvoton NCT6793D/NCT5563D
System Specs:​
ComponentDetails
BIOS Date06/16/2018
You can now follow the guide and configure the EFI for KBL.
After your recommendation, I have update the configuration of system :
System Specs:​
ComponentDetails
BIOS Date06/16/2018
in this new config with this efi and a new error : here
Were you able to create the EFI using the guide?
fly.gao
