Sequoia Installation Issues
Successfully updated to Sequoia 15.1.
I had to download the full installer via Mist.app because it wasn’t showing up in Software Update within System Preferences.
Everything works perfectly. No Apple Intelligence, as it’s not available on x86.View attachment 8718
You can use RestrictEvents to fix the update thingy. A guide is already available on the forum!
Has the crashing issue fixed now?
hubalala
