bluetoothd opens the wrong USB port.
Do I need some more DSDT patches?
I'm keeping trying to solve it.
Any advices are welcome.Thank you.
Thank you for an advice.
Unfortunately, BT port was NOT detected (NOT highlighted green on Hackintool).
To check the BT's port,I injected only following kexts.
Lilu.kext
VirtualSMC.kext
SMCSuperIO.kext
SMCProcessor.kext
SMCLightSensor.kext
SMCBatteryManager.kext
WhateverGreen.kext
VoodooPS2Controller.kext
Are there any ideas to solve it or investigate the cause?
You must inject USBInjectAll+XHCIUnsupported+XHCIPortLimit Quirk.
You should also ensure that the BT is not disabled from BIOS.
Thank you for replying again.
This PC is configured multi OS.
And in other OSes,BT works well.
So,This is not caused by BIOS settings.
And... could you tell me the minimum kexts?
I think that at least, VirtualSMC and SMCSuperIO must be injected to boot.
And VoodooPS2Controller is also required to operate in MacOS.
Please read the post again. Those kexts and quirk has to be added as an addition to the existing configuration.
I tried an USBMapping with the minimum kext.
But It did NOT solve my problem.
So,I think the cause is NOT USBMapping.
Therefore,I will investigate the route from PCI to USB and DTST etc.
Anyone have other idea,Please tell me.
After that(USBMapping),I found that the IntelBT must be attached to USB Hub.
I compared it to my other PC which has Intel and can boot Sequoia.
(Of cause,IntelBT works well on this PC in Sequoia.)
IntelBT and Wifi(Wireless 8260) is placed at
/PCI0@0/EXP3@1C,2/PXSX@0.
On the IORegistryExplorer,
Intel wifi (itlwm) was attached to that position(/PCI0@0/EXP3@1C,2/PXSX@0).
And IntelBT was attached to IOUSBHostDevice (HS07@1440000).
On the other hand, the PC on this problem and USB2.0Hub at 14800000 (HS10).
So bluetoothd must open NOT 14400000 (HS05) but it.
No files attached
All you were supposed to do is inject USBInjectAll+XHCIUnsupported+XHCIPortLimit Quirk. Clean in Hackintool. Attach a copy of System Report, IOReg and Hackintool>USB section picture.
Write your reply...
cons_
