bluetoothd opens the wrong USB port.
Do I need some more DSDT patches?
I'm keeping trying to solve it.
Any advices are welcome.Thank you.
Thank you for an advice.
Unfortunately, BT port was NOT detected (NOT highlighted green on Hackintool).
To check the BT's port,I injected only following kexts.
Lilu.kext
VirtualSMC.kext
SMCSuperIO.kext
SMCProcessor.kext
SMCLightSensor.kext
SMCBatteryManager.kext
WhateverGreen.kext
VoodooPS2Controller.kext
Are there any ideas to solve it or investigate the cause?
You must inject USBInjectAll+XHCIUnsupported+XHCIPortLimit Quirk.
You should also ensure that the BT is not disabled from BIOS.
Thank you for replying again.
This PC is configured multi OS.
And in other OSes,BT works well.
So,This is not caused by BIOS settings.
And... could you tell me the minimum kexts?
I think that at least, VirtualSMC and SMCSuperIO must be injected to boot.
And VoodooPS2Controller is also required to operate in MacOS.
Please read the post again. Those kexts and quirk has to be added as an addition to the existing configuration.
Ryota.Alfa
