SOLVED Headphone Jack Prob
ready2000
MSI MAG MORTAR MAX WIFI B550M
RYZEN 5500GT
RTX 3050 INNO3D 8GB
15.x
Hi, it is the same PC
MSI B550M Mag mortar max wifi
Ryzen 5500GT, 16gb ram, 512+512gb ssd
So, the thing is that, I have a monitor connected, and Audio is working very well using any ALCID from 1 to 100. 28 works well, so I have chosen that.
I have Headphone Jack on the front of my PC and on the back also (back is complicated, different jack for left right so on)
Audio doesn't come from any of the Headphone Jack
I want to connect headphone to front jack, but it seems as if undetected.
On linux, 3 audio cards are shown, card0,1,2, where 0 is NVIDIA GPU Card (useless), 1 is ALC1220 and 2 is ATI R6xx (added codec dump for these two.)
This is the Audio control connected from which Monitor Audio is working.
When I connect headphone in headphone jack in linux, Family 17h/19h shows up.
Searched in hackintool and found this in PCIe:
So please help me in getting audio in headphone, as Wifi+BT card is MTK7921K that cant be used in MacOS. So please help me
(I love it so im tagging sorry @EliteMacx86 )
Also, in Terminal using asound -l something on linux,
When I connected Headphone, ALC1220 Digital showed subdevice 1/1
and when disconnected, it showed ALC1220 Digital 0/1 and ALC1220 Analog 1/1
And it seems that HDMI (monitor) Audio is ATI R6xx as it also says HDMI and monitor is connected via HDMI and I can hear audio...
So what is the problem??
What you show in Hackintool is the HDMI Audio and does not reflects the onboard Audio. There are problems reported with the Sequoia and AppleALC. So, first thing you should do is verify on Windows or Linux.
Secondly, you've been told before to follow rules. You agreed to it when signing up. One more tagging without waiting for 24-48hrs, will lead to permanent ban!
Okay, Okay, will never do it
As i told you, it is working on windows and linux, and on linux, it shows up as 'Family 17h/19h controller.'
Here is the Image of the 3 controllers on my PC. 1st one is useless as I said.
Also, the headphones are not even detected :(
Of course, these are PCI IDs. But the Hackintool>Audio only shows your GPU Audio. So, something might be wrong with the implementation. Does the Audio works via the rear port?
Yoo any updates?
Remove the DeviceProperties. It has no values so delete that first.
The rest seems to be fine.
As per the IOReg, the AppleALC is not attaching. You can try spoofing the Device ID to an older one which is supposed to work. If that doesn't, switching to VoodooHDA may help.
ANARKRUTOI
